Headlights making sounds!
Old Mar 27, 2008 | 11:20 AM
gnawlidge's Avatar
gnawlidge
Default Headlights making sounds!
My head lights make a sort of a knocking sound when I open or close them. Funny that it also does this when I turn just the running lights on or off. Can anyone shed some LIGHT on the subject?
Old Mar 27, 2008 | 11:21 AM
RacerX70CC's Avatar
RacerX70CC
Bushings are worn out... only a matter of time before you have a "winker".
Old Mar 27, 2008 | 01:15 PM
jhammons01's Avatar
jhammons01
But since it is a '92...I can't tell you exaclty how to fix it. there are Stickies at the top that have directions.
Here it is......
http://forums.corvetteforum.com/show....php?t=1848666
Old Mar 30, 2008 | 11:10 PM
gnawlidge's Avatar
gnawlidge
Default update
The operation of the headlights opening and closing seems to be fine. After I turn the switch to "OFF" the arm that connects to the headlight
housing jostles around and makes the knocking sound. It moves slightly and it does this on both lights simultaneously. It does the exact same thing whether I am just turning off the running lights or the headlights. Is that really the bushings going out?
Old Apr 28, 2008 | 02:47 PM
Mileage's Avatar
Mileage
gnawlidge,
My 90 seems to be doing exactly the same thing. Sometimes when go out to the garage a while after parking, both headlights are jostling. The motors' manual ***** seem to be trying to turn. If the bushings were bad, I would think they would be spinning. Did you find the problem?
Old Apr 28, 2008 | 03:26 PM
jhammons01's Avatar
jhammons01
Wow, 30 days later and the answer or advice is still the same.
Your bushings are out. See the sticky thread at the top of the page for the fix.
Understand...and for future reference (anyone else checking this thread) There is a switch in the Headlight circuitry that reads the voltage....when the headlight hits the stops....it creates a voltage spike....the switch reads that spike and tells the motor to stop running. If the gears are grinding inside the motor due to the gears being stripped or the bushings being out (early years and later Years respectively) the spike never occurs and the motor keeps cranking along creating the noise you hear and the hopping you see.
Read the sticky and fix your headlights. it is a two hour job that cost less than ~$50
Old Apr 29, 2008 | 02:51 AM
MostWanted's Avatar
MostWanted
You can easily do this fix yourself for under $10.00. You can get the bushings at Autozone. They are the same bushings used in the power window motors of Fords. After buying the bushings...all it takes is time and patience while following the directions in the thread.
Old Apr 30, 2008 | 03:10 PM
jim_hewett's Avatar
jim_hewett
Better yet...measure the ones @ AZ then buy them in bulk @ Lowe's.
So you've got to cut them to length...you've only got a dollar invested anyway!
Cheers
Check your 6
Old May 1, 2008 | 02:46 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
It's your bushings. The correct repair link has already been posted.
Old May 1, 2008 | 07:24 PM
JnC96CE's Avatar
JnC96CE
Itll look like this.
Old May 1, 2008 | 07:28 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Here is link to the instructions for replacement
http://home.comcast.net/~zrjuan/headlight.html
Old May 8, 2008 | 07:52 PM
Mileage's Avatar
Mileage
jhammons01,
Wow, 10 days later and the answer or advice is still wrong!
All,
I supported my local vette parts store and bought the bushings from them. I installed them last night in about an hour and a half. The second side was much easier and quicker. The old bushings looked pretty good. Maybe a little out of round but solid and unbroken.
Symptoms remain the same: Lights work, open and close, little manual ***** do not set and spin, headlights jostle and make a knocking sound after they close.
Any other suggestions? I hate being a "parts changer".
Old May 9, 2008 | 02:24 PM
onedef92's Avatar
onedef92
Originally Posted by Mileage
jhammons01,
All,
What year Vette? The C-4s have two different headlight motor designs; 1984-1987 and 1988 through 1996.
Old May 14, 2008 | 01:23 PM
Mileage's Avatar
Mileage
Mine is a 1990. I believe gnawlidge has a 1992. Everything looked clean inside the gearboxes of mine. I did not disassemble the motor portion. Exterior linkage looked good. Thanks for the help.
Old May 29, 2008 | 02:15 PM
tombueh's Avatar
tombueh
6th Gear
Default headlight noise
mine are making noise also, its like the motors continue to turn when i turn the lights off, this also happens when i disconnect the battery and when i reconect the battery the motors engauge not raising or lowering the lights
Old May 29, 2008 | 02:28 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
That would be the good ole plastic bushings.
Old May 29, 2008 | 02:51 PM
ajax_mp's Avatar
ajax_mp
I had same problem, part of it was the gear the bushings went in.
did you check the gear ?
My guess is that could be part of the problem, I changed both of them when I changed the bushings, everything works fine.
Old Jun 30, 2008 | 01:26 PM
Mileage's Avatar
Mileage
As noted above my bushings and gears were fine. I replaced the control module located on the left fender liner. It took about 2 minutes. Now they work fine. The key to diagnosing if it is bushings/gears or the control is if the motor **** continues to spin. It is also fairly easy to hit the wires going to the motors with 12v and then reverse the polarity and hit them again. If the lights work fine, the problem may be upstream of the gears. Someone hamfisted might want to put a fuse in the line before trying that. I do not know how robust the motors are.
To Headlights making sounds!
