Washed my engine
you drowned the Opti. While your pricing a new opti I suggest you replace water pump as well. Its a while you are there kinda of deal that will save you trouble later. Sucks bro good luck
If you do a late model vented opti, you'll need to swap your front cover and internals to the late model parts. I also recommend new seals for the distributor and waterpump drive seals. Felpro makes a set TCS 45956 that give you everything you need for a late model front cover. My distributor drive seal was pretty bad and was leaking and I wound up swapping out my seals and eliminated another leak.
Larry
Your opti is probably corroding inside and might quit at anytime. Get AAA with free towing and hope for the best. The vented GenII opti will not fit on yours without alot of other modifications (not worth it). Check out the MSD vented opti for your year.
Havent washed mine - but brought up question
Getting ready to put on long tube headers , all new exhaust to the rear. While at it replacing plugs, wires, belt, 64k LT 1 95 6 sp. Also new distributor cap, and rotor -- understand they are a bear cat to install --
Any secrets on the headers (Stainless Works) - and most importabaly the distributor cap, and rotor, see some washers in there, checked forum - most agree that's all required --any special tools required, besides 3 ole gear heads, have convinced them these newer cars read directions 1st
dont need that on our older none electonic ones -
I get horrible gas milage - when testing and not all over it the best I can get highway at 70,15 to 16 rpm is about 20 to 21 MPG, around town when testing and lead out of foot is about 12 to 15 - any ideas -- runs sharp, crisp, 93 oct, idles well. I use the math not the gauge
Wish this had spell check
Oh well any help you can provide would be appreciated on all of the above would be appreciated -- sorry profile doesnt show this car - my 91 was sharp also
Len
Now ya know that will teach
