anyone knows what was wrong?
Old Apr 5, 2008 | 03:53 AM
Jonathon1990vette's Avatar
Jonathon1990vette
Default anyone knows what was wrong?
so i filled up two to three days ago. and my gauge doesnt work so i go by miles. anyway as im driving the car starts to spudder as if its running out of gas. i pull over and i turn it off. i crank it a couple times it starts then turns off as if no gas. so i walk to corner store buy a little tank put a half gallon and put it in the car. it then starts up fine i drive to gas station and fill up, only it only took about 7 gallons. so that means i was never out of gas.... anyone knows what could have happend? its running fine now.
Old Apr 5, 2008 | 04:08 AM
Jonathon1990vette
or just dont trust a 18 year old car....
Old Apr 5, 2008 | 04:26 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
you will need a FSM - Helms
Alot of different options:
check for error codes
injectors
fuel filter
pump
vacume leak
fuel switches
and the list goes on
Old Apr 5, 2008 | 09:38 AM
leafsmainiac's Avatar
leafsmainiac
Probably the fuel filter needs to be replaced. I had a simillar incident years ago. Once, I replaced the fuel filter everything was cool. that is where I would start. But getting a FSM is a great idea.
Old Apr 5, 2008 | 02:35 PM
Jonathon1990vette
I searced around for it and im still pretty new to the scene i cant figure out if the FSM - Helms is a book or a computer you hook up? thanks and either or where you do you get it?
Old Apr 5, 2008 | 02:46 PM
Wayne88's Avatar
Wayne88
injectors
fuel filter
pump
vacume leak
fuel switches
First check the vacuum lines for a leak, and change your fuel filter.
Old Apr 5, 2008 | 04:21 PM
Matatk's Avatar
Matatk
FSM = factory service manual - get a reproduction of it at helminc.com
Matthew
Old Apr 5, 2008 | 09:04 PM
navyndi2's Avatar
navyndi2
fuel filter would be the first thing i'd change.
Old Apr 6, 2008 | 07:36 AM
89 Bob L's Avatar
89 Bob L
Change the fuel filter, and check your codes.
To anyone knows what was wrong?
