An idea
Old Apr 9, 2008 | 09:32 PM
Allieboy's Avatar
Allieboy
Default An idea
with the price of premium going higher combined with the failure of ethanol would it be dumb to buy octane booster and use regular.
its been awhile since ive priced octane booster so if this is dumb show mercy
Old Apr 9, 2008 | 09:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If your owner's manual specifies regular with base timing don't mess with a "booster".
Old Apr 9, 2008 | 10:09 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
If your car "requires" premium it would be cheaper to buy that grade of fuel, than to buy regular grade and add octane booster. The reason is you would need multiple cans in order to raise the octane enough to matter.
Don't believe all the "hype" behind the octane booster adds.
As 65Z01 mentioned, make sure your car really needs the higher octane first.
My LT4 owners manual says mine requires premium of 91 or higher. The LT1 recommends premium of 91 or higher for best performance. But you may use regular or mid grade, but your vehicle may not accelerate as well.
Not sure what the L98 manual says.
Old Apr 10, 2008 | 04:57 PM
Allieboy's Avatar
Allieboy
Is this true gents?
thx
Old Apr 10, 2008 | 05:06 PM
jesters94's Avatar
jesters94
2016 C4 of the Year Finalist
2015 C4 of the Year Finalist
Is this true gents?
thx
The manual does recommend 91 but it is not required.
Been using midgrade in my 94 for 2 years with no problems on wood.....
Old Apr 10, 2008 | 05:29 PM
All2kool's Avatar
All2kool
Octane Boosters boost the octane by less than 2%, meaning less than half a point.
Old Apr 10, 2008 | 07:04 PM
RollaMo-LT4
Is this true gents?
thx
From the 1996 owners manual (6.3 and 6.4)
Old Apr 10, 2008 | 09:13 PM
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
I'm a premium guy in all my vehicles and gas powered engines.
Old Apr 11, 2008 | 11:12 AM
kalister1's Avatar
kalister1
The LT-1 has knock sensor, it will (HEAR) the knocking/pinging and take some timing out of the engine. That is why it will not accelerate as fast. The higher octane number is more resistance to knock, not more energy.
Old Apr 11, 2008 | 11:54 AM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
Good info in post #7.
I never put anything but the best in the car, as I want it to perform well, and not have problems down the road. If I have to go to regular gas because I can't afford it, I think I would park it instead of running regular.
Old Apr 12, 2008 | 08:07 AM
Rapid Fred's Avatar
Rapid Fred
I also have an LT1 and have found that using less than the recommended octane for an LT1 also hurts mileage a bit, so you really don't save any money. Regular won't hurt the car because of the knock sensor, but sluggage performance with lower MPG does not appeal to me.
Even if the MPG were the same, the savings per year from using regular might be $4-$5 per tankful, or at most $100-$200/year if yours is a DD. Considering what people on this Forum invest to get a few extra HP......
Old Apr 12, 2008 | 08:19 AM
9tred's Avatar
9tred
Old Apr 12, 2008 | 08:53 AM
lt4obsesses's Avatar
lt4obsesses
1) Just one bottle of octane booster will make a tank of mid grade more expensive than a tank of premium.
2) Octane booster will not improve anything significantly.
3) I have read where some booster/fuel system cleaners may actually cause damage to our fuel injectors.
Furthermore, I have tried using midgrade in my lt4. While I did not have any real troubles with knock or the like, I did notice that my mpg's decreased. Thus I was paying the same anyway.
Better off just biting the bullet and getting premuim. I have accepted the fact that I just need to cut back on joy riding
Old Apr 12, 2008 | 09:52 AM
jabez's Avatar
jabez
Cost wise you will lose out. I have seen octane boost from 8-12 dollars.
If you fill your tank with 15 gallons (using 1 bottle of 10.00 octane boost) thats like adding .65 per gallon. The difference between premium and midgrade is not close to that.
Old Apr 12, 2008 | 02:52 PM
aboatguy's Avatar
aboatguy
Most OCTANE boosters are a waste of your money.
Mike
Old Apr 13, 2008 | 01:29 AM
Arkybill's Avatar
Arkybill
The place I buy gas has preium (93 octane) and when I'm down about 1/2 a tank, I'll fill up with the mid-range gas (89 octane) that gives me 91 which is what the owner's manual calls for. I've had to buy some low octane (85) in Colorado and it didn't knock, but I could tell the car didn't run as good. Really didn't see any loose of mileage.
To An idea
