Oil Pressure Sensor
Old Apr 9, 2008 | 10:04 PM
SpeedyKev42's Avatar
SpeedyKev42
Default Oil Pressure Sensor
When I drive my 88 Corvette, the oil pressure always reads 80 psi on the digital dash, and it never changes... whether idling or driving at higher speeds. I believe that the oil pressure sensor is bad or possibly corroded. Can anyone tell me where it is located on the engine?
Old Apr 9, 2008 | 10:20 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Mine does the same thing -- the new sensor goes in when I get to it
PS - it's been in the tool box for 18 months
Old Apr 9, 2008 | 10:21 PM
JackDidley's Avatar
JackDidley
You are probably correct. It is below the distributor, to the driver side.
Old Apr 9, 2008 | 10:23 PM
RICEKILA's Avatar
RICEKILA
But then again I bought a fuel filter at the same time -- he gave me the wrong one
Old Apr 10, 2008 | 12:02 AM
Radco10's Avatar
Radco10
When you decide to change the sensor, you may consider changing the switch too (the short one, at about 45 degree angle) since you will be in there. I changed mine last week on my 91 L98, and I must say, it was a bear getting to the sensor. I originally planned to change the switch because it was leaking up through the switch out of the electrical connector. I bought a sensor at Pep Boys and changed it at the same time. Now my oil pressure drops to zero at idle after it gets hot. Point being, I should have bought an OEM sensor! To gain access, I pulled the distributor cap, pulled the plug wires out of the way, loosened the intake tubes just so I could get a 1 1/8 inch wrench on the sensor. The switch will come off with a 1 1/16 deep well socket.
Old Apr 10, 2008 | 02:45 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There is an Al stalk comming up from the rear engine land to the right of the dist. Both the oil pressure sensor and the oil pressure switch are located into the sides of that stalk. The oil pressure sensor is the one with only one wire.
Old Apr 10, 2008 | 11:28 AM
Calderone's Avatar
Calderone
Are you having presssure problems or its the sensor/switch failing ?
Old Apr 10, 2008 | 11:41 AM
Calderone's Avatar
Calderone
i have just changed them
they look like this
here pictured with the fitting
Old Apr 10, 2008 | 01:33 PM
Radco10's Avatar
Radco10
Pressure. When idling after it is hot, oil pressure drops to zero, gauge bottoms out. During normal driving, gauge follows throttle. It was working fine before I changed it.
Old Apr 10, 2008 | 01:48 PM
Calderone's Avatar
Calderone
- Why you changed it ?
- What brand did you choose ?
Old Apr 10, 2008 | 02:43 PM
Radco10's Avatar
Radco10
Because I was in the area since the switch was leaking, I thought I would be a little pro-active. I believe it is a dura-last (auto Bone). I'm thinking about going to the Dealer to get an AC Delco sensor. P.S. My drawing shows the switch as the short one (one wire). Is that not right?
Old Apr 10, 2008 | 03:01 PM
Calderone's Avatar
Calderone
where is your drawing ?
Old Apr 10, 2008 | 03:15 PM
Radco10's Avatar
Radco10
I couldn't figure out how to post it!
Old Apr 10, 2008 | 03:21 PM
Calderone's Avatar
Calderone
Go to imageshack.us an upload it
then copy the code and link from the field "Hotlink for forums"
To Oil Pressure Sensor
