Gid, Ken posted on the forum earlier that he was having problems with one of his pieces of equipment and it was locking up the forum. Said he hoped to have it fixed by this week end
Where did you get that idea? it was the old forum that crashed, this one is new!
Marck
I had trouble before the new server, and when trying to access your new server seems it’s reflecting the old problems. I also take issue with having to set my privacy settings (cookies) to a lower standard then I prefer in order to access that site. In order to access that forum I have to keep my privacy setting at “Low” whereas most sites such as this forum lets one set and accept cookies at a medium security. I just have an obsession about things that don’t work correctly. It’s like owning my Corvette. If the smallest thing isn’t just right, I will spend hours and sometimes days until I locate the problem. I also spend ample time and money on preventive maintenance in order to prevent malfunctions. I hope you don’t think I am bad rapping you or your site. On the contrary, I would do anything to assist you in anyway I could to promote or assist you with any transition problems you may be having. You see, my third field of expertise is Computers. Hope you have no hard feelings.
No hard fgeelings at all, I did see you are a registered member over there. Are you using IE6? We have heard more about security issues under IE6. We're currently investigating what causes this.
Its been back up for awhile. Ken does do a little work now and then. When i go there, i never have problems. I am running IE6. I much rather the new forum than the old one.
Tweenie ...yes I am using IE6 with Win 2000 Professional
Cecil ..If you are using IE6 Go up to the top of this window, Go to TOOLS> OPTIONS> PRIVACY>and put your Setting for accepting Cookies on Low. You shouldn't have any problems after that.
