Mobil I
Old Apr 16, 2008 | 12:38 PM
redvette6spd's Avatar
redvette6spd
Default Mobil I
I have a sort of a dumb question I want to pick up a oil change for my LT4 on my way home from work and I cant remember the weight of Mobil I to buy Thanks
Old Apr 16, 2008 | 12:43 PM
Aardwolf's Avatar
Aardwolf
What I usually do is use 5-30 then as the engine wears, say 100k miles, switch to 10-30. I live in a climate that is not hot all the time though. A hot or cold climate may affect your choice.
Old Apr 16, 2008 | 04:04 PM
skybolt31's Avatar
skybolt31
The oil needs to meet the GM4718M specification, the only Mobil 1 that I could find that says on the bottle that it meets that spec is the 5-30. The penzoil platinum in 5-30 and 10-30 meet it. Those were the only ones that I could find that meet the spec.
Old Apr 16, 2008 | 04:39 PM
redvette6spd
I got the 5-30 thanks
Old Apr 17, 2008 | 12:09 AM
rws.1's Avatar
rws.1
Old Apr 18, 2008 | 10:24 AM
DVNCI's Avatar
DVNCI
I've just started switching my higher mileage vehicles to 10W-40.
Just changed from 5W-30 to 10W-40 in my truck and it quieted down.
Aardwolf - you probably know this but not much difference in 5W-30 and 10W-30 - once warm they are the same weight so you are only seeing slightly thicker oil when the engine is cold.
Old Apr 18, 2008 | 10:48 AM
Aardwolf's Avatar
Aardwolf
Yes the 40 sorry! It will fill in the bearing wear.
Old Apr 18, 2008 | 11:41 AM
DVNCI's Avatar
DVNCI
To Mobil I
