Are They Kidding!!
Old 04-22-2008, 01:46 PM
myblue91
myblue91's Avatar
Default Are They Kidding!!
My 91 coupe with 145,xxx mi. has started to leak from the rear tranny seal. Called the local dealer and asked how much to R&R the seal,and due to the miles,and since the driveshaft has to come out, to do the ujoints also. They quoted me a rate of 9-10 hrs. labor @ $90.00/hr. Was told the trans has to be removed!!. I'm basically lazy,and if I could leave the car with someone in the morning,and p/u in the evening great!,but for this kind of money I think I'll try doing this myself. Dealers ,now I feel better. Doug
Old 04-22-2008, 01:52 PM
DaleD
DaleD's Avatar
But, if they do the job, and don't mess it up, (a big IF), then there's nothing wrong with their price. Dealers have to make a buck too. Given the cost of space, tools, techs, and other overhead, $90/hr is not unreasonable.
I was using a local independent dealer to fix things I couldn't, or didn't want to fix myself. It seemed every time I took it to them, something else magically broke. I just used a local GM dealer, yep, they charge $90/hr, but it was worth it. They did what I wanted, and the car ran fine after they finished. I don't mind paying for fair value.
Old 04-22-2008, 02:08 PM
myblue91
myblue91's Avatar
Dale- I don't have a problem with their rate,but with trans R&R for the rear seal!! that's BS!! Doug
Old 04-22-2008, 02:32 PM
tcr75
tcr75's Avatar
think about where the seal is located. They may be able to do it with the trans in the car but I am sure the book tells them to pull it out. Get a second opinion from a transmission shop
Old 04-22-2008, 02:45 PM
RacerX70CC
RacerX70CC's Avatar
Rear transmission seals don't "just leak"... the most likely cause is a worn extension housing bushing. You need to replace it along with the real seal, and it can be done without pulling the transmission using the proper tools. I usually get 3 hours labor plus parts to do the bushing, seal and driveshaft U-joints (it's already out), so 9 hours is likely the labor op to pull the trans.
Find a better shop (NOT a transmission shop!)
Old 04-22-2008, 03:05 PM
myblue91
myblue91's Avatar
Racer- thanks for the addtional info re the housing.I'm slowly learning
Old 04-22-2008, 11:49 PM
Powersmokin
Powersmokin's Avatar
yes I call b/s on that I replaced my rear seal with out removing the tranny and did it in less then 1hr and the seal was abut $26 and if it is the zf 6 speed you cant get the bushing any more at least I could not find it any where not even the dealer.
To Are They Kidding!!
Quick Reply: Are They Kidding!!
