Looking to get a C4, need advice
Old Dec 14, 2001 | 08:58 PM
CrazyMagMan's Avatar
CrazyMagMan
St. Jude Donor '05
Default Looking to get a C4, need advice
I found a really nice C4 today. It's a 95 with 80,000miles, and the car cruises great, no stumble on acceleration or acting up at all, but it has a slight lope at idle. The lot had just received the car about 3 days before and it still had the previous owners things in it. It obviously had not been cleaned by the lot and the engine compartment was almost spotless. The car was obviously well taken care of, as there was not a squeak nor leak to be found, and it drove out beautifully.
Guess my concern is the idle. Is it normal for C4's to lope a little? My thought is probably new plugs, wires, throttle body and injector cleaning would probably smooth it right out. The car had sat for three days without anyone driving it and it definitely smoothed out after it warmed up.
Any help is appreciated,
Poe :confused:
Old Dec 14, 2001 | 10:10 PM
IndianaJef's Avatar
IndianaJef
Default Re: Looking to get a C4, need advice (mgbgt74)
There are alot of good C4's out there right now. You might want to keep looking for lower mileage. I just got mine in September and without even looking hard, found one with 24,000 on it. It runs real smooth at idle. Of
course if the price is nice then you may want to grab it.
Old Dec 14, 2001 | 10:44 PM
CrazyMagMan
St. Jude Donor '05
Default Re: Looking to get a C4, need advice (IndianaJef)
Price is 15995, but I offered 14500, and he seemed like that was okay. This guy has alot of inventory on his lot right now, so he is looking to move cars as he has no more room. I will look at it closer tomorrow, and let everyone know the outcome. It is Bright Aqua Metallic with just a couple small scratches and think it has the G92 option as it pulled alot stronger than the 94 rattle trap I drove last night.
Is that price high? I haven't seen anything else in this area under $17500 in decent shape and under 90,000 miles. :eek:
See ya,
poe
Old Dec 14, 2001 | 10:51 PM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
my '93 does not lope at all (the 85 does due to the cam) I'd suggest having it looked at by a corvette mechanic. I bought the 85 in IL and paid a lot more for it than it would run here, price is regional so you would know what's fair by the local market. See if you can contact the old owner to find out what's wrong with it!
Old Dec 14, 2001 | 11:56 PM
91Vette's Avatar
91Vette
It might be worth your time to have it checked out by a reputable mechanic or Chevy dealer to see if it's in good running order. I'm not sure how much a service like that costs, but it's a heck of a lot better than spending $14.5K on a mistake.
Best of luck.
Old Dec 15, 2001 | 02:32 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Looking to get a C4, need advice (91Vette)
I agree on having it checked out... thats a fair price for the car.. the idle might be plugs/tune up.. could be the start of opticrap failure which would be an expensive repair. My 95 has a pretty smooth idle...
Old Dec 15, 2001 | 03:09 AM
SPEEDEMON's Avatar
SPEEDEMON
The best thing for you to do is to make sure you have someone that knows what their doing and have them inspect that problem completely. Hate to see you be married to problem from the beginning, also in 95 they only built 909 Bright Aqua's!
Old Dec 15, 2001 | 04:02 AM
dmalhi1's Avatar
dmalhi1
i think ya should keep looking
you can find one with much lower mileage
my 88 has like 76,000 miles on it and i picked it up just a month or so ago
Old Dec 15, 2001 | 08:27 AM
Ed Ut's Avatar
Ed Ut
I wouldn't worry about the rough idle. Most likely it just needs some new plugs.
Old Dec 15, 2001 | 07:48 PM
CrazyMagMan
St. Jude Donor '05
Default Re: Looking to get a C4, need advice (Ed Ut)
Thanks for all the help. I am definitely going to keep looking as I found a few more things I didn't like today, such as burnt tranny fluid. Think I will try and sell the Neon and then get a C4. At least that way I may get a little money for the little thing.
See ya,
Poe
Old Dec 15, 2001 | 10:49 PM
wake's Avatar
wake
Also, if you're not used to the LT1 motor, it might seem like it has a slight lope/miss at idle... When I bought my first LT1 car new (T/A), I thought there was something wrong with it until the dealer showed me a few other new cars on the lot that ran the same way...
The LT1 does idle a little rough by nature... My MSD ignition box cleaned it up a lot, both on the T/A and the Vette...
But definately get it checked out and ask someone on here with an account to run a carfax for you to help make sure it hasn't been in a major accident... Sounds like a decent car...
Old Dec 17, 2001 | 02:38 AM
fdcaptain's Avatar
fdcaptain
Go for the newest you can afford.
To Looking to get a C4, need advice
