i have a set of painted sawblades ,i stripped them and i dont think these can be polished.where can factory paint be purchased or does anyone know of an alterative that is close to factory color
If they're aluminum, they can be polished. Sand them with 320, then 400, then 600. Then take green polishing rouge and go to town. It's long, tidious, and a pain in the rear end, but they'll look like mirrors when your done. Better than factory. If you really want to paint them, any PPG store will have something called silver wheel paint. (no kidding) It's a nice middle-of-the-road silver that looks good on wheels.
they can be polished and you can do it yourself with great results if you take your time. I kept sanding all the way to 1500 grit paper and then used Mother's aluminum polish. They'll look like a million bucks afterwards and then you can clearcoat them if you wish.
I would be careful with the bead blasting. If you go that route I would make sure they only use plastic media when they do it. It is way to easy to get carried away using sand or glass media. Ask me how I know...
My rims are rough where they have hit curbs and where they have been balanced, will sanding and polishing using all these procedures repair them. Then will I have to repaint and clear coat. I don't understand the process but would like to try it. These are my factory 87 rims with the gray center caps. Any more info will help.
You can use small dremel , die grinder or drill with a finer cartridge roll and smooth the rash out. Take your time, watch the speed on the roll.
If your flanges are "curb-rashed" you'll need the services of a wheel restoration or repair shop. You don't need the shop to do the entire refinish or polish but you'll need them to weld, repair and turn the flanges. A quality shop will want to do all four of your wheels as a set so that when he's finished all the flanges will match. It's not required but you'll be much happier if you have all four flanges done to match.
Before you commit to the repair, polish or what ever to your wheels have them "spun" to confirm they're "true"!
those wheels look great,my original zr1 wheels are the ones i want to polish.thats how im going to go.looks better than painted.my current wheels are A molds you once owned.
