95 rattles
Old May 3, 2008 | 09:55 PM
ELKPHOTO's Avatar
ELKPHOTO
Default 95 rattles
Any thoughts on rattles on my 95 coupe; sounds like it's coming from left rear, inside, but hard to pinpoint. Anybody else out there.
Old May 3, 2008 | 11:01 PM
pianoguy's Avatar
pianoguy
Could be the brake lines. Get under there and tap them to see if they rattle. If they do, the FSM says to zip-tie them together to eliminate the rattle.
Old May 7, 2008 | 03:20 PM
thebeerman's Avatar
thebeerman
Look in your FSM, they have an entire section on rattles - no joke!
Old May 7, 2008 | 03:22 PM
Master__Shake_'s Avatar
Master__Shake_
It's a rough riding car, they make noise. You should take a ride in mine sometime.. sounds like a dog's squeaky toy when I drive down a bumpy road.
Old May 7, 2008 | 03:40 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Perhaps, but there is a world of difference between an 86 and a 95. The late model C4 had a heck of a lot of dampening material placed in strategic places to significantly reduce the rattles & squeeks.
A proper condition 95 should NOT have squeeks & rattles even going over a section of railroad tracks. Now it is true that over time I have replaced all 4 wheel bearings and put in a new set of FX3 shocks and even replaced a few ofthe bushings. But I drive every day and do not have squeeks & rattles.
Your best source for chasing down those rattles is your FSM.
Old May 7, 2008 | 03:43 PM
JimiHendrix's Avatar
JimiHendrix
Default Sway bar links?
I found that the rubber bushings in the rear sway bar links were completely worn away. Once it was fixed. . . the car was tighter and quieter over bumps..still squeaks with the targa lid off tho...
Old May 7, 2008 | 04:56 PM
jcb5565's Avatar
jcb5565
Old May 7, 2008 | 07:27 PM
96polovette's Avatar
96polovette
Spend some time with a screwdriver tightening every interior screw you can locate in the car. Over time they loosen up. This may eliminate a good portion of the rattles.
To 95 rattles
