rotating tires
Old Dec 16, 2001 | 04:12 PM
Jsailor24's Avatar
Jsailor24
Default rotating tires
On my 87 can i rotate my tires by just taking one side wheels off and switching them? Do this for both sides of course. F&R tires are the same width on my year right?
Old Dec 16, 2001 | 05:32 PM
vader86's Avatar
vader86
Default Re: rotating tires (Jsailor24)
yes you can rotate front to back, just dont put them on the other side.
Old Dec 17, 2001 | 02:51 PM
vette87's Avatar
vette87
Each of the wheels are marked as to the location where they belong. But you should still be able to move them from front to back. ;)
Old Dec 17, 2001 | 03:36 PM
scorp508's Avatar
scorp508
I think only if you have Z52 or Z51. If you don't, the front rims are 8.5, and the rear are 9.5.
Old Dec 18, 2001 | 01:03 PM
BBA's Avatar
BBA
Default Re: (scorp508)
My 87 with base suspension came with 8.5" wheels all around, with the same size tires. I used to rotate mine every 3-4 months.
Old Dec 18, 2001 | 02:03 PM
JonM's Avatar
JonM
On an 84 the rims are a different size (front and back) also directional. So there is no rotating the tires unless you remove them from the rims.
Old Dec 18, 2001 | 09:31 PM
red-y's Avatar
red-y
I rotate buying the front one year then the rear the next year. :crazy:
To rotating tires
