ecm help
Old May 9, 2008 | 10:14 AM
blkzr1's Avatar
blkzr1
Default ecm help
hi, will the 1994 ecm for an lt1 six speed interchange with the 1995 lt1 six speed ecm? thanks for any information
Old May 9, 2008 | 12:30 PM
DVNCI's Avatar
DVNCI
The proper term for 94 and later is actually PCM, Powertrain Control Module, because they started controlling transmission function, etc.
But yes, the 94 and 95 PCM's are 100% the same. And the auto and 6 spd's are the same PCM - only the programming is different. So in other words you could use a PCM from an auto car but you would have to flash it.
