Door Ajar Light on!!!!!!
The side of the car that allows the door panel interior light to come on is the immediate culprit, but I'd replace both of them, because if one's gone ****-up, the other's sure to follow.
You can get them for under $15 at your Chevy dealer.
most probably the door switch(es) not being depressed enough to open the circuit and tell the CCM that the door is closed.Try just pushing in the door switch, does the 'door ajar' light go out?
If so, then another fix, assuming the switch still has its plastic 'nose' (a flat head with shaft -- which pulls out of the center of the switch plunger to provide self-adjustment), then if you can pull it out, put 2 little rubber o-rings behind its flat head. This will keep the self-adjusting 'nose' sticking out further and hopefully contact the door jam sooner and push in the switch further and thereby create the open circuit which should turn off the 'door ajar' light.
If by chance the switches are just shorted and no longer 'open' the circuit, regardless of the switch being pushed-in, replacement can be done right through their hole in the door, and do not require the door to be taken apart. See your FSM or do a search.
