Optispark Install With Pics
Old May 11, 2008 | 04:27 PM
CAP94's Avatar
CAP94
Good work! Let us know how it runs when you're done..
Old May 11, 2008 | 05:09 PM
RogerZ06's Avatar
RogerZ06
Originally Posted by pianoguy
I would suggest getting the balancer on and the coil (don't need to bother with the belt) for a quick fire-up to make sure it works before putting the water pump back on. Just don't let it run for more than a few seconds.
OK I tested it and it fired up but died shortly after. I didn't have maf intake hoses connected or the water pump.
Old May 11, 2008 | 05:45 PM
pianoguy's Avatar
pianoguy
Hmmm, that's interesting - when I test-fired mine, it didn't die. I had warning lights on due to the coolant sensor, MAF, etc. being disconnected, but it ran fine. Again, I only let it run for a few seconds, since there's no coolant in the engine. I would assume, though, that since yours started OK, things are hunky-dory.
Old May 11, 2008 | 05:48 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Not a good sign. You can run it for more than a few seconds the engine won't catch on fire . Make sure you have a ll sensors attached and make sure it will run till you turn it off. Even with the maf off it should run in SD mode. Hook up the coolant sensor and IAT. And try again. It should run and idle fine at this point.
Old May 11, 2008 | 06:11 PM
RogerZ06's Avatar
RogerZ06
Plugged all the senors in and it stayed running. Now gonna take another break and finish up water pump and belt.
Old May 11, 2008 | 06:17 PM
pianoguy's Avatar
pianoguy
Good to hear! Don't forget to use plenty of thread sealant on the water pump bolts ;-)
Old May 11, 2008 | 06:32 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old May 11, 2008 | 10:42 PM
RogerZ06's Avatar
RogerZ06
OK everything is finished except for coolant. I'm gonna flush it with water then fill it with 50/50.
Also had problem with belt not fitting right. I got size 667 and it was to small. I got one size bigger 672 and it worked fine.
Old May 12, 2008 | 12:53 PM
RogerZ06's Avatar
RogerZ06
Now when the car warms up I have slight miss at idle and under acceleration.
Guess the wires move and touch header on pass side.
