Sun Visor ?
Old May 13, 2008 | 04:01 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Sun Visor ?
Where can I buy sun visors for a reasonable price?
Mine cant be rebuilt, the cardboard is dry rotted and I would like to have lighted mirrors. Mine does, but they're so bad, that you can barely see yourself.
Old May 13, 2008 | 04:03 PM
85vette-84vette's Avatar
85vette-84vette
Just remove them. It will look
Old May 13, 2008 | 04:04 PM
Syclone354's Avatar
Syclone354
I thought about removing mine since the covering is getting pretty rough. whats involved in deleting them?
Old May 13, 2008 | 04:44 PM
rickneworleansla's Avatar
rickneworleansla
There was a place that used to rebuild them cheap. In Tennessee maybe. I thought they replaced the insides with plastic.?
Let's see some pictures without the sunvisors.
Old May 13, 2008 | 04:53 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
The main street I drive on goes east and west, I have to have sun visors!!!
Old May 13, 2008 | 05:04 PM
Inlove's Avatar
Inlove
All the ones I looked at are cardboard. How about removing them and dropping them off at a reputable upholstery shop to be rebuilt with something that will last.
I removed mine, does look better, but I understand why you can't.
Old May 13, 2008 | 05:05 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Corvette Central - http://www.parts123.com/parts123/yb.dll?parta~partsort
Ecklers - http://www.ecklers.com/search.asp?ac...searchHistory=
Zip - http://www.zip-products.com/Zip/sear...=false&GiftID=
Corvette America - http://www.corvetteamerica.com/cf/di...3A%20sunvisors
Old May 13, 2008 | 06:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
About three winters ago I needed a "snow project" so I pulled both visors, took them completely apart, molded new cardboard and hand sewed them up with a nice black padded covering. Cost was maybe <$20 for both sides. The new cardboard "ears" are holding up very well but I'm careful to not abuse them now.
If the mirror glass needs to be replaced, when you have the mirrors out during the visor rebuild process, have a good glass shop cut you two new pieces of glass to fit. BTW, use some caution when pushing a mirror back into the masonite board that runs the center of the visor.
Old May 14, 2008 | 06:07 AM
clay69's Avatar
clay69
I'm not sure where on here but there was a guy who had a way to repair the limp visors by inserting a small strip of plastic looked real nice to.
Old May 14, 2008 | 07:31 AM
ynk1121's Avatar
ynk1121
http://mysite.verizon.net/brianjbalo...unvisorfix.pdf
Old May 14, 2008 | 07:39 AM
rich653's Avatar
rich653
Also have them on e-bay, used or new. bradscorvettes $69. ea
Old May 14, 2008 | 12:04 PM
BlackbirdZ07's Avatar
BlackbirdZ07
So that's all there is to it? Just push some plastic under the mirror housing and it goes right under the fabric on the other side? No sewing, no nothing? Sounds too easy, but I'll certainly try it out. Thanks!
Old May 14, 2008 | 12:38 PM
thebeerman's Avatar
thebeerman
"I'm not sure where on here but there was a guy who had a way to repair the limp visors by inserting a small strip of plastic looked real nice to."
Take one of the narrow metal blind strips from an old one, cut with tin snips, slip in above the mirror, or make a slit on the end.
Old May 14, 2008 | 01:00 PM
Capt. Mike's Avatar
Capt. Mike
I recently tried this repair using heavy abs plastic, it worked great.
To Sun Visor ?
