Sun visor's
Old May 16, 2008 | 03:16 PM
lilredc4's Avatar
lilredc4
Default Sun visor's
I am going to recover my sun visor's this week and was wondering if anyone had ever attempted to remove the vanity mirrors to recover the visors. If so, how are they separated. The car is a 92 Coupe.
Old May 16, 2008 | 06:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Yep, been there done that.
There are two rubber posts with flairs on the ends on the back of each mirror. These posts extend through a masonite center board and hold the mirrors in place. Once the fabric is off and the cardboard opened you can push the rubber posts back through the masonite, freeing the mirrors.
On my project the fabric was shot along with the cardboard so I bought some construction cardboard cut to shape and then moistened one side so I could bend and mold it to shape without creasing it.
I was afraid to press on the mirror glass hard enough to push the rugger posts back though the masonite so I carefully worked the glass out of the rubber surround, installed the rubber onto the visor and then carefully worked the glass back into its rubber holder...PITA...
If you only need to install new fabric and the new stuff has enough "streatch" I wonder if you could work it around and under the mirrors without removing them???
Old May 16, 2008 | 07:58 PM
Jim D's Avatar
Jim D
Jim, how did you sew the visors, I'm about ready to tackle this project, PS I don't have a sewing machine Jim.
Old May 17, 2008 | 12:15 PM
lilredc4's Avatar
lilredc4
Thanks; I have a sewing machine, but have never removed corvette sun visors or any other for that mater with a vanity mirror. I also need to replace the cardboard in mine, but was not sure about the rmoval of the vanity mirror. Thanks for the info
Old May 17, 2008 | 02:07 PM
65Z01's Avatar
65Z01
Jim, how did you sew the visors, ...PS I don't have a sewing machine Jim.
Neither did I so I made it a "winter project" and sewed them up by hand; first I pinned the cloth into position, removing pins as sewing progressed. I used maybe 5' of thread and "walked it out" for the early sewing stage......but hey it worked very well.
You will need to remove the cap over the visor retainer. Then you will see a speed nut; here I used a small flat blade and small hammer to rotate the nut up the shaft. Be aware that there is a spring under the speed nut. I think I had to drop the corner of the header trim to access the electrical connection???
The cardboard I used was very smooth on one side and relatively stiff. By wetting it along and around the center line I was able to gradually bend it over without creasing thereby retaining full strength after it dried to the desired shape.
I used a black fabric with a thin foam backing that very well matched the OEM look and gave a nice "padded" feel to the finished visor.
Good luck with the project, just take your time and have fun with it...
Old May 19, 2008 | 04:15 AM
moserbe's Avatar
moserbe
Old May 19, 2008 | 09:30 AM
daddysvet92's Avatar
daddysvet92
Default This might help!
Use these pictures with 65Z01 ' s step by step procedure - I've been there and done that also, but my neighbor sewed on cut the material for me for free because I snowblow his sidewalk in the winter time.
Old May 19, 2008 | 07:42 PM
lilredc4's Avatar
lilredc4
Would like to say thanks to daddysvet92 and 65Z01, for their post, it helped a lot. I finished the sun visors today and they turned out great The rubber post going through the Masonite was a bit tedious, but it worked out. Great forum
Old May 19, 2008 | 10:32 PM
Eddywill's Avatar
Eddywill
Wow wish my neighbor had sewing machine because here in Florida I help them board up for Hurricanes....
AWESOME photos - I am ready to tackle this after I get done with the other 18 things on my list!
To Sun visor's
