1988 temperature gauge help ???
Old May 17, 2008 | 04:56 PM
Noobster's Avatar
Noobster
From: My Give A Dams Busted The Bend Me Over State N.J
Default 1988 temperature gauge help ???
I want to hook a back up temperature gauge on my car . The main one is acting funny. I got a gauge and it says tap into with a T fitting. Looking for some pointers as well as where does the stock one plug in ? The block or the radiator ? Thanks
Old May 17, 2008 | 05:53 PM
Hooked on Vettes's Avatar
Hooked on Vettes
The temperature sender used by the digital dash is screwed into the passengerside head between the 6 and 8 spark plug. Has a single wire spade lug type connector.
Old May 17, 2008 | 08:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you don't have the booster fan you can remove the plug in the block below #1 & #3 spark plugs, though that plug can be a pita I've heard.
Old May 20, 2008 | 09:26 PM
Noobster's Avatar
Noobster
Has anyone tried this ?
Old May 20, 2008 | 11:13 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Wanna share with the group why you are doing this before we proceed?
Old May 21, 2008 | 01:27 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Instead of sitting their tapping your foot, try searching C4 Tech for info, check the C4 Tech Tips, and you'll prob find your answer, your not the first to try it...
Old May 21, 2008 | 01:29 PM
SunCr's Avatar
SunCr
To verify your gage, disconnect it - that should read LO. Then ground the signal wire and it should peg somewhere around 300. Next, hook up a scanner and compare the display to the Coolant Temp Signal. There shouldn't be more than a 5 degree difference. If these tests are ok, you need a new Sender (or you have an intermittent connection at the Sender). If the gage is off, you need a new or rebuilt Cluster.
To 1988 temperature gauge help ???
