Remote question
Old May 20, 2008 | 03:50 PM
mattyg92's Avatar
mattyg92
Default Remote question
hello all! not use to being on the C4 side, but i recently bought a 1993 and i have a question about the remote, i was trying to program it, but i did notice that it "rattle's" when you shake it, is this a normal noise, or is it trash?
thanks!
Old May 20, 2008 | 04:18 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
they are not suppose to rattle. If you open it you will Polly see the contacts around the battery the goes the circuit board are broken off. That is what was wrong with mine when I bought it. I took it too a little electrical repair place and had them soter them back together.
Old May 20, 2008 | 07:03 PM
Red Dwarf's Avatar
Red Dwarf
Both of mine have a very slight rattle. I was told that's what wakes up the transmitter so that it is not transmitting all the time, as if, if you left your fob in the car & locked it you can open the locks (door) by shaking the car to activate the FOB (pke). If I'm wrong please correct me. Thanks.
Old May 20, 2008 | 07:07 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yes, they very well could rattle slightly!
Mine does, and it works perfectly
As Red Dwarf said, it's a very slight rattle though.
Old May 20, 2008 | 08:09 PM
Goldcylon's Avatar
Goldcylon
True statement the rattle comes from a ball bearing that rides loose inside. You want this rattle as it does indeed wake up the remote. The rocking the car method is hit or miss but will work if the ball bearing rocks.
Old May 20, 2008 | 10:17 PM
mattyg92's Avatar
mattyg92
ok thank you for the info!
i need to reprogram my remote now, i think the problem i had before while trying to program it was that i had the remote with me, and the instructions say to have it away from the car until it flashes?
Old May 21, 2008 | 12:19 AM
Arkybill's Avatar
Arkybill
I've got a 94 LT1 and it came with an orginal fob (I got it in 2006). The orginal fob did rattle, I've had it apart to change the battery, and it's got a little cage with a ball in it, that's what rattles. Also, if you leave the key in the ignition, you can shake the car and it will unlock-I've done this several (3) times. It's always worked.
About a year ago, I bought a new fob-off the internet. Looked new in the package. It was held together with 2 screws (the old one was held together with tape-the locking tabs had broken). Anyway, the new one does NOT have the cage and ball, but, it still works when you walk away from the car and wakes it up when you approach it. Only thing, if you leave the key in the car and it locks the door, shaking the car does NOT work. Tried it last weekend, me and a friend almost picked the left rear quarter off the ground several times and no luck.
just for your info.
bill
To Remote question
