1996 wiring problem
Old May 24, 2008 | 12:13 PM
dragan's Avatar
dragan
3rd Gear
Default 1996 wiring problem
okay I hope that this is the right section to post this and if not hoppfully I will be pointed in the right direction.
The story: Okay my neighbor has a 96 vette that someone stole the pcm and cut off two of the four connectors that went to it.
My neighbor now has a new pcm and connectors that goes to it but the connectors do not have the same wire color code as the car harness. so I managed to get a hold of a pinout diagram with color codes from alldatapro.com but the car is missing wires that the diagram says that I should have, like 1-4 upshift control wire, and output/field service enable, engine oil temperature sensor signal, transmission fluid temperature sensor signal, and one of the two serial data (UART)
what I need are addition pinouts for a 1996 vette convertible for the black and blue connectors with the color of the wires that goes to each pin.
if this is too confusing just tell me and I will try to make it a little bit more clear.
Old May 27, 2008 | 12:20 PM
dragan's Avatar
dragan
3rd Gear
what I am asking for is very simple, I just need to know what wire color goes to what numbered hole in the black and blue connectors for the pcm
Old May 27, 2008 | 12:28 PM
Sweet 90's Avatar
Sweet 90
I did a quick search and found this for a '93. Maybe will help
Jim
PINOUT for GM PCM/ECM 16159278 (wire color abr. follows descriptions)
Wire Color Legend
B = Black
BL = Blue
BR = Brown
DKBL = Dark Blue
DKG = Dark Green
GY = Gray
LBL = Light Blue
LG = Light Green
O = Orange
P = Purple
PK = Pink
R = Red
T = Tan
W = White
Y = Yellow
Connector [A] is Gray
[A1] Vapor Canister Purge Solenoid DKG/Y (HOT in start and run) 10A
[A2] EGR Solenoid B/PK (HOT in start and run) 10A
[A4] IAC LBL/W
[A5] IAC LG/B
[A6] Check Engine Light BR/W (this grounds when light is on, connect other terminal on light socket to HOT in start and run) 5A
[A7] Air Pump Relay BR
[A8] Air Divert Valve BR (this grounds when active, connect other terminal on valve to HOT in start and run) 10A
[A9] Shift Light W
[A10] IAC LBL/B
[A11] IAC LG/W
[A12] Ignition Coil W (HOT, connect other black wire on coil to ground) 10A
[A13] Coolant Temp Sensor Y
[A20] Fuel Pump ON input R
[A21] Trans Position Switch O/B
[A22] Anti-lock Brake Module GY/B
Connector [b] is Red
[B2] Trans Converter Clutch (Auto) or Overdrive Relay (Manual) T/B (Auto) or DKBL (Manual) (also connects to Pin F on ALDL Connector)
[B3] MAP Sensor B
[B4] Primary Cooling Fan Relay DKG/W
[B5] A/C System DKG/W
[B6] Grounded T (also connects to Pin A on ALDL connector)
[B10] Secondary Cooling Fan Relay DKBL/W
[B14] 2nd, 3rd and 4th gear switches (auto), 4th gear LBL
[B16] Cruise Control System P
[B17] Grounded B/W (jumped to [B6] )
[B18] TPS B
[B19] 2nd, 3rd and 4th gear switches (auto), 3rd gear DKG
[B20] 2nd, 3rd and 4th gear switches (auto), 2nd gear W
[B21] A/C system DKG/Y
[B22] Grounded B/W
Connector [C] is Green
[C1] A/C system DKG
[C2] TPS GY
[C3] PS DKBL
[C5] Distributor/Opti-Spark Module B/R
[C6] HOT at ALL times (jumped to C17) O
[C7] MAP Sensor GY
[C8] Knock Sensor(s) DKBL
[C9] Distributor/Opti-Spark Module B/PK
[C11] A/C Pressure Sensor GY/R
[C12] ECM Power (HOT in start and run) PK/B 3A
[C14] Distributor/Opti-Spark Module P/W
[C15] Oil Temp Sensor DKG
[C17] HOT at ALL times (jumped to C6) O
[C18] Distributor/Opti-Spark Module Y
[C21] MAP Sensor LG
[C22] Manifold Air Temp Sensor T
Connector [D] is Brown
[D1] VSS P
[D4] ALDL and Serial Data Connector T (connects to Pin M on ALDL connector)
[D6] O2 Sensor (left) P
[D7] Fuel Pump Relay DKG/W
[D8] VSS Output DKG/W
[D10] Fuel Injectors 2, 4, 6 & 8 DKG (connect other lead off injectors PK/B to HOT in start and run 10A)
[D11] Fuel Injectors 1, 3, 5 & 7 DKBL (connect other lead off injectors PK/B to HOT in start and run 10A)
[D12] VSS Y
[D15] ALDL and Serial Data Connector T
[D20] ALDL and Serial Data Connector W/B (connects to Pin B on ALDL connector)
[D22] O2 Sensor (right) P
Old May 31, 2008 | 07:53 AM
dragan's Avatar
dragan
3rd Gear
sorry no it doesn't my connectors are red, black, clear, and blue. Also the harness does not have some of the colors mentioned in the information that u gave me. but thank you for the help anyway.
To 1996 wiring problem
