Another Optispark failure maybe...
Old May 25, 2008 | 07:37 AM
jim_hewett's Avatar
jim_hewett
Default Another Optispark failure maybe...
94 LT1 6sp, had 1.6RR's installed along w leaking exhaust gaskets (7&8).
Rockers were properly zero back lashed at each TDC & further tweeked @idle. Nothing disturbed electrically. Very smooth idle. Test drove w much improved acceleration until @ turnaround when engine died @ idle restarted OK w slight miss. Returned to garage couldn't accelerate beyond 72mph engine faltered & finally died in front of garage unable to restart.
Owned this little red beast for 12 yrs. Replaced first OS last Aug w new eng change.(127K) 2nd failure due to pin hole leak in TB hose and a pigtail failure(OS to coil).(142K) Bought the MSD distr for mothballing. Good timing maybe. The beast is currently in the garage awaiting checking thrown codes. How bout your insights on this??
Cheers
Check your 6
Old May 25, 2008 | 10:16 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Check your fuel system/pressure.
Old May 25, 2008 | 10:41 AM
jim_hewett's Avatar
jim_hewett
Did..good pressure. Changed out the fuel tree & pump last wk
Old May 25, 2008 | 12:07 PM
zr1fred's Avatar
zr1fred
Then I'd look at the ignition module and coil. (Don't forget the fuel filter). But yeah, it could be a broken cap or rotor.
Old May 25, 2008 | 05:04 PM
jim_hewett's Avatar
jim_hewett
Thank you sir...will proceed along those lines.
Cheers
To Another Optispark failure maybe...
