C4 fuel issues
Old May 28, 2008 | 06:42 PM
lincoln007's Avatar
lincoln007
8th Gear
Default C4 fuel issues
85 corvette will not start. Have no power to the the fuse box @ the the ep fuse. Have check all the fuses for power and the only fuse in the fuse box that has no power is the ep fuse. Suspect that i have a bad ground, however everything else on the car works. Anything else I should look at?
