For the fist time, I have my vette at a shop to get fixed (LT4). I have always done all work myself, but I simply do not have the time right now.
So here is the deal.
I am having the valve seals changed, any I talked to my mechanic yesterday, asking how he was progressing.
I became aware when we where discussing it, that I doesn’t do this as I would have done!
He don’t set zero lash, where you turn the push rod between your fingers, at a given position for the valve.
He just put the rocker back on, and tightens it down. Told me that’s the way to do it on these cars.
I am not sure here, when I replaced the rockers to RR 1.6 on my 87 I turned the engine and set zero lash on each..
If its anything like a gen 1 (which i think its basically the same, most of the valvetrain is interchangeable with an L98) Hes full of ****. Id talk with him again before you end up with bent pushrods or other valvetrain damage.
A couple of quick questions- My L98 needs valve seals, what is a reasonable cost for a shop to do this? Is there special equip. needed or is it DIY?
It is not a terribly difficult job. You need a way to hold the valve closed (compressed air through the spark plug hole to pressurize the cylinder) and a valve spring compressor. There is a device that attaches to the rocker stud to accomplish this.
If your mechanical inclined and have a FSM and a basic set of tools you can get it done it certainly will be the cheapest way out, even if you have to buy a valve spring compressor and a couple of misc items you'll probably only spend $100 parts and all, if you have a friend that's done the job it's time to invite him over. If you have to farm it out anything around $300-400 is a bargain and I seen a lot of shops charge a $1000 or more. Problem is on these old cars other stuff breaks or is worn out when you take them apart like rockers,push rods, ign wires,hoses etc. Good luck.
