How do I remove this.....
Old Dec 20, 2001 | 10:35 AM
Redding's Avatar
Redding
Default How do I remove this.....
Just got it and love it but trying to keep it all orginial only has 42k miles. The past two owners justed loved on this car.
Any suggestions on how to remove this sticker with out hurting the paint or car.
I hope the images help show you me predicament.
Old Dec 20, 2001 | 10:41 AM
Ed Ut's Avatar
Ed Ut
Default Re: How do I remove this..... (Redding)
Use Goo Gone. I would squirt it all around the edges of the sticker and let it absorb really good.. Then use a hair dryer to warm up the adhesive and gently lift if off. Keep squirting the goo gone as you remove it. Goo Gone is harmless to your paint and is great for removing sticky adhesive.
Old Dec 20, 2001 | 10:43 AM
black86targa's Avatar
black86targa
Default Re: How do I remove this..... (Ed Ut)
Let it soak for a while with WD40. Be aware the paint may have faded a little leaving an unfaded spot where it is. :cool:
Old Dec 20, 2001 | 10:50 AM
Redding's Avatar
Redding
Thanks, Where do you suggest I will find Goo Gone?
Old Dec 20, 2001 | 11:24 AM
DaveFromCleveland's Avatar
DaveFromCleveland
Home Depot has Goo Gone in the adhesives section and the checkout lines. After soaking it, you can use fishing line to get behind the emblem and cut through the adhesive. Then use more Goo Gone to clean it up.
Old Dec 20, 2001 | 11:36 AM
2HIP4U's Avatar
2HIP4U
If you're not a fisherman, I've heard dental floss will work
behind the offending badge and help work it loose. Don't
be afraid to use lots of goo remover.
:seeya
Old Dec 20, 2001 | 11:42 AM
scorp508's Avatar
scorp508
Default Re: How do I remove this..... (2HIP4U)
I personally prefer 3M Tar/Adhesive remover, but goo gone and WD-40 will work fine. :)
Old Dec 20, 2001 | 11:57 AM
jbatjr's Avatar
jbatjr
I have to agree the goo gone works great I have used it many times in as many different kind of applications. You can find it at the home depot or any supermarket. It works great on cleaning up the leftover stuff from inspections stickers, vinyl, etc....
Old Dec 20, 2001 | 01:20 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: How do I remove this..... (jbatjr)
Keep it off the letters underneath the badge if you care to keep those on the car.
Old Dec 20, 2001 | 01:38 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: How do I remove this..... (Vette92)
Good Point :yesnod:
Old Dec 21, 2001 | 01:23 AM
fdcaptain's Avatar
fdcaptain
Do it like the pros...a heat gun should do the trick. If you don't own a heat gun, try a blow dryer. The goo gone is also a good idea, just giving you some options.
Old Dec 21, 2001 | 01:56 AM
Mr. CJ's Avatar
Mr. CJ
Cruise-In I Veteran
Default Re: How do I remove this..... (CowboyNVette)
Fishing line works wonders!
Old Dec 21, 2001 | 08:15 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: How do I remove this..... (Mr. CJ)
Here's another vote for fishing line. I replaced the hood and gas tank emblems on a warm day with some 12lb monofilament line. No damage to the paint at all. Just cleaned up the residual adhesive with a little WD40.
Old Dec 21, 2001 | 11:55 AM
JoeVette88's Avatar
JoeVette88
Default Re: How do I remove this..... (Alchemist)
It helps if you take the fishing line off the rod 'n reel. Also remove the hook or any type of lure before you attempt this. :D
Old Dec 21, 2001 | 12:15 PM
TrplBlk01's Avatar
TrplBlk01
:yesnod: :yesnod: :yesnod:
To How do I remove this.....
