A/C delete
Old Jun 4, 2008 | 04:23 PM
jispr's Avatar
jispr
Default A/C delete
Locked up my compressor at WOT. Guess I should have turned it off.
Smoked the belt. I would like to bypass the compressor till later (the clutch bearings sound like they make lock up too) Is there a belt available to do this? 93 stock lt1, two sided ribbed belt.
Jim
Old Jun 4, 2008 | 11:23 PM
Greg0u812's Avatar
Greg0u812
Only way I know to do an a/c bypass is with a bypass pulley. I think they are about $60. A shorter belt won't work because of the way they have to run around everything else.
Just re-read your post.:o
Not sure about how the belts routes around an LT1 (I was thinking of the L98). Might be able to do it with a shorter belt on that one.
Someone with more knowledge than me will surely chime in on this.
Old Jun 5, 2008 | 02:08 AM
AZC4Guy's Avatar
AZC4Guy
Uhh people are using shorter belts on l98's, they are just routing it around the tensioner the other way.
Old Jun 5, 2008 | 02:19 AM
Greg0u812's Avatar
Greg0u812
cool.....that's two thing I've learned here today.
Old Jun 5, 2008 | 04:45 PM
DVNCI's Avatar
DVNCI
Just FYI, I assume your car would be the same, but A/C shuts off anyway at WOT so probably wouldn't have mattered if you had shut it off manually or not.
To A/C delete
