Need 1985 fuse panel layout
Old Jun 10, 2008 | 07:37 PM
Ricksmc's Avatar
Ricksmc
3rd Gear
Default Need 1985 fuse panel layout
I just purchased a 1985 Vette and there is no manual with it. Can somebody copy a layout diagram or description, in particular, the large relay/fuses.
Old Jun 10, 2008 | 10:45 PM
C4boy's Avatar
C4boy
I'm pretty sure this is for an '86, but it should be similar minus the ABS
Old Jun 11, 2008 | 07:02 PM
Ricksmc's Avatar
Ricksmc
3rd Gear
Thanks for the response but this is not the same as what I have. I only have two large breakers on the right and one is missing. I'm just trying to see what size fuse it is and if it is for the power accessories.
Old Jun 12, 2008 | 01:12 AM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
This is from my 85 owner's manual.
Hope this helps
Mike
Old Jun 12, 2008 | 04:03 PM
Ricksmc's Avatar
Ricksmc
3rd Gear
captmike13: That is what I needed. Thanks, you guys are great.
Old Dec 9, 2014 | 07:20 PM
Tired 85's Avatar
Tired 85
2nd Gear
CaptMike13, thanks for the 85 fuse box diagram. Excuse my inexperience, but does anyone know why the fuse location labeled "tail" is indicated to protecting the headlamp switch? Could it also protect the tail lights? I don't see a separate fuse location indication it's for the tail lights. Thanks.
Old Dec 11, 2014 | 01:52 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default Yes it does the tail lights.
if it is same as my 87. and some dash lights as well. like the transmission gear indicator lights.
Old Dec 11, 2014 | 05:02 PM
Tired 85's Avatar
Tired 85
2nd Gear
Thanks Viking, I replaced that fuse and got my tail lights back....and my fog lights too!
To Need 1985 fuse panel layout
