brake caliper tool
Old Jun 11, 2008 | 11:22 AM
finally_got_it's Avatar
finally_got_it
Default brake caliper tool
where can a guy find a good tool for compreesing the brake calipers on these cars?
-Chris
Old Jun 11, 2008 | 11:31 AM
StealthLT4's Avatar
StealthLT4
I got mine from Mid-America for $30. You should probably try Harbor Freight, as they may have something cheaper. However, I was placing an order there anyway, so it was convenient. One of the best investments I've ever made!
Old Jun 11, 2008 | 11:42 AM
BobRR3's Avatar
BobRR3
You can just use a "C" clamp
Old Jun 11, 2008 | 11:47 AM
rickneworleansla's Avatar
rickneworleansla
I go to harbor freight for tools with few moving parts. They are cheap and usually get the job done. My Harbor Freight torque wrench became a breaker bar after a couple of months. Still comes in handy though. I even used it to ward off some would be thieves once, worked very well. I use the old pads and a large screw driver for pressing the pistons in on the calipers.
Old Jun 11, 2008 | 11:52 AM
blkc6z51's Avatar
blkc6z51
Here these work good.
http://www.sears.com/shc/s/search_10...5&gobutton.y=6
Old Jun 11, 2008 | 12:09 PM
SCCA VETTE's Avatar
SCCA VETTE
I have a BIG pair of channel locks that i use and just squeeze the piston in.
Old Jun 11, 2008 | 12:10 PM
ZumZum's Avatar
ZumZum
I use a C-Clamp. Just leave the pad in so you get equal pressure on the caliper.
Old Jun 11, 2008 | 07:41 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
"Ditto"
Old Jun 11, 2008 | 08:29 PM
efweber's Avatar
efweber
Large C-clamp. It's cheap, and it has more than one use.
Old Jun 11, 2008 | 09:57 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
(I always stick a pad used pad in there, never the clamp directly to the piston)
and, of course........
Old Jun 11, 2008 | 10:09 PM
03blackburb's Avatar
03blackburb
Old Jun 12, 2008 | 07:15 AM
MarkBychowski's Avatar
MarkBychowski
I like the rubber coated woodworking c-clamps. You can work them with one hand (the 'trigger' type) and they won't scratch up your calpier.
Old Jun 12, 2008 | 10:33 AM
finally_got_it
thanks guys for all the good input!
Old Jun 12, 2008 | 10:51 AM
Keystring's Avatar
Keystring
I just use a pry bar.
Pull the outer pad and put the caliper back on the rotor with the inner pad in place. Put the pry bar between the caliper and rotor and pull slowly. I use a thin piece of wood to avoid damaging the rotor, but if you're careful, it won't damage it without the wood.
To brake caliper tool
