Service Engine Soon
Old Jun 13, 2008 | 06:46 PM
WHbrown66@aol.com's Avatar
WHbrown66@aol.com
Navigator
Default Service Engine Soon
"Service Engine Soon" Display comes on stays a few minutes gone for a few days, then back on for a few minutes. 93 Vette LT1 57k miles. Is this oxegen sensors? something else? Don't have any computer stuff for codes whats the obvious? Do have all the manuals----
With this gas thing I have been ******* the vette to work at 62mph
getting around 25-27.5 per gallon on a 21 mile trip I am impressed, but maybe the ******* it is the issue and I need to get this vette up to speed again.
Appreciate the help
Wayne in San Jose
Old Jun 13, 2008 | 06:54 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Use the paper clip trick, put one in the top right ALDL pin and the other end in the bottom left and turn the key to the ON position. Then post back w/your results.
ALDL is under the dash right by your right knee.
Old Jun 13, 2008 | 10:17 PM
jabez's Avatar
jabez
Originally Posted by Randy93
Use the paper clip trick, put one in the top right ALDL pin and the other end in the bottom right and turn the key to the ON position. Then post back w/your results.
All you need is a paper clip to pull your codes.
Old Jun 13, 2008 | 10:25 PM
RACER 1993's Avatar
RACER 1993
If the SES lamp doesn't stay on then your probably going to have to search the CCM for history codes. This is all explained in the part of the manual that covers CCM diagnostics. You use the DIC to retrieve them. That is the Trip/Odo button and a couple others there to scan through them. DIC is driver info center. Then when you get the numbers if any set and look them up. It could be anything.
To Service Engine Soon
