throttle sticks
Old Jun 17, 2008 | 02:13 PM
silverman6602's Avatar
silverman6602
Default throttle sticks
does anyone know where I can get a new spring for the throttle mechanism? the one I have seems to be getting weak and isn't returning the throttle when I let my foot off the pedal. its an 89' tpi.
thanks
Old Jun 17, 2008 | 08:18 PM
JackDidley's Avatar
JackDidley
That problem is not usually a weak spring. The throttle shaft tends to wear out the holes that it rides in, in the TB causing irregular throttle return. If its the spring, its not real common.
Old Jun 19, 2008 | 10:27 AM
silverman6602
Thats very possible. I took the TB off and cleaned it, and it worked ok for a few weeks. is there any way to fix that? or do I need a new TB?
To throttle sticks
