bumper help
Old Jun 17, 2008 | 04:11 PM
harleymarkt's Avatar
harleymarkt
Default bumper help
i have a 1990 c4 will a front bumper off a 91-95 fit it if so what else do i have to buy to put it together
Old Jun 17, 2008 | 05:41 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Should just need the front inner fenderwells.
Old Jun 18, 2008 | 12:52 AM
DANSURE1's Avatar
DANSURE1
Default 91 Mybe
92 Up Bumper cover Light or not the same.
Old Jun 18, 2008 | 12:59 AM
DANSURE1's Avatar
DANSURE1
Default 92 up
Fender Wells will work, but like i said you need more lights.
Old Jun 18, 2008 | 01:40 AM
harleymarkt
thanks i wrecked mine and i like the newer front end better
Old Jun 18, 2008 | 04:54 PM
Port A Vette's Avatar
Port A Vette
Default There is alot of work and parts involved
I just had my '96 bumper cover off last weekend to replace the skid/crash bars on the bottom as mine got smashed in an offroad incident (I drove off the curb at an unfamiliar gas station ).
You'll also need the foam energy absorber and under bumper structure as well as the lights that that have been noted. Also you'll need the wiring and possibly the skid bars and all the parts if yours are toast. There are alot of fasteners involved plus the spoiler and the spoiler supports. You'd probably be better off getting everything from a late model Vette that has been rear ended. If you can get access to a FSM they have some very good exploded views that help to put all the parts in perspective. It is labor intensive and I recommend you get a 7 mm ratcheting wrench. I used a standard wrench and my fat fingers to remove all the screws along the hood hinge line. A ratcheting wrench would have come in handy there.
Larry
Old Jun 18, 2008 | 04:56 PM
jakers's Avatar
jakers
St. Jude Donor '06
Larry
If you need the lights, I have a set for sale in the C4 Parts /Wanted section.
To bumper help
