96 Water Pump Replacement
Old Jun 18, 2008 | 06:36 PM
papafrancisco's Avatar
papafrancisco
Default 96 Water Pump Replacement
How diificult is it to replace a water pump on a LT1? I have heard the horror stories of getting the opti-spark wet. I have the FCM's. Is there a trick to draining the system to prevent water from getting into the opti-spark? Thanks for any help or directions
Old Jun 18, 2008 | 09:29 PM
aminnich's Avatar
aminnich
No problem at all. Hook up a shop vac to a heater hose and suck the coolant out. Then just to be safe cover the opti with some plastic wrap.
Old Jun 18, 2008 | 10:00 PM
pianoguy's Avatar
pianoguy
Pull the knock sensors on each side of the engine to drain the block. Even after you drain the block and the radiator, there will be a small amount of coolant in the pump, so make sure the opti is covered.
To 96 Water Pump Replacement
