With the high cost of gasoline I was curious if anyone could tell me what grade is recommended in my 1994 Vette. The fuel door says premium, and I have been running that. Will regular un leaded work just as good?
The doors says premium for a reason. My advice is to follow those instructions. Even the price of gas is high, the price of the engine repairs will be much higher!
I believe 93 octane is recommended. I can actually use 87 or even 85 without problems, but I am at significantly higher elevation than you are. Your car should automatically adjust the timing to prevent knocking if you use regular, but you could notice some loss of power due to the milder timing correction.
Guess I'll just have to keep putting premium in it. Definately don't want to have to pay the high cost of engine repairs just to save 40 cents difference on gas
The engine has knock sensors which will retard the timing with lower octane fuel--retarded timing equates to less power---so that your driving habits being the same--you would burn more fuel to do the same amount of "work"--that said what you save in price per gallon you would likely spend in the amount of fuel you used--and as others stated the long term affects on the engine may not be good--you can't go wrong using what the factory recommends !
Drive it less if you want to save of fuel that's what I'm doing. I used to drive mine to work during summer, but with the stop and go traffic that kills fuel mileage, I only use the car on weekends now which is fine with me.
Assuming this question is really related to the cost of premium over regular, please consider the following. I been using Lucas Upper Cylinder Lubricant for a couple months in my L98 and family car (Camry), I'm getting about 1 to 1 1/2 mpg more around town in the vette and on trips in Camry (with some local driving) 34.7 mpg. The Camry EPA rating is 32 MPG for trips so something is happening using this additive. Give it a try.....
Same here i use reguler 87 with the lucas upper cyclender lubricant and i noticed a increse in my miles per tank i get.
BTW i noticed it on my way back from the corvette assembily plant and museum, coincidence maby you be the judge of that......
I don't believe the factory recommendation changes, nor does an engine's operation change, when the numbers over the pump do.
I really don't see how the cost of a base gallon of gas relates to the octane people use. It still costs $.20-30 more per gallon for premium over regular, just like it did when gas was $1.50 a gallon.
The book on my 96 says to use at least 91 octane; I use 93 in mine. It's only $4 more to fill the 20 gallon tank with the good stuff over the low octane gas.
Well apparently no one has really answered the question, so I will step in and voice my opinion.
Since your year LT1 is rated at 10.5:1 compression, I would recommend either 89 or 91 octane to run at full performance. You should be able to slide on 89 since the compression isn't sky-high, and you don't drive at WOT all the time.
If you want a middle-ground, or can't find 91, mix 89 and 93 - but you should be fine with 89.
Hmm... I thought his question was answered? He asked what grade gasoline is recommended for his '94. And he answered it by saying his fuel door says "Premium Fuel Recommended". I'll go take a look at my car again, but I'm fairly certain there is no asterisk next to it with the disclaimer "only when gas is less than $4 a gallon".
What fuel is recommended, and what works, has nothing to do with the price of that fuel.
I was very close to a purchase of a C5 a couple of weeks ago from the local Chevy dealer. It had a strange knock in it and only had 27000 miles. The sales staff and the mechanics couldn't hear it. A friend of mine and I could hear it, and once you did...it sounded a lot like a rod knock, just not quite as loud. Any of us would run from a purchase of a car with a knock.
The dealer called last week to tell me they finally found the problem. One of the salesmen had put regular gas in it.
I'm sure the sale will go through...but they lost a $26,000 sale from me from using LOW OCTANE GAS.
Exactly, and with his motor and compression the highest he HAS to run is 91. Everyone either stated regular or premium, and nothing was said about the motor. Just because some people baby their low compression motors, doesn't mean everyone has to. You'll eventually lose gas mileage if you run too high of octane for extended periods of time.
I don't mean to put you on the spot here but that is a big mistake that a lot of people make. One octane is not better than the other. An octane rating is the resistance of a fuel to ignite. Running a higher octane than what is need actually hurts performance and gas mileage. You should run the lowest octane you can without a knock. For my LT1 it's 91.
