Cleaning Engine Comp.
Old Jun 23, 2008 | 10:07 PM
miks139's Avatar
miks139
Default Cleaning Engine Comp.
I know you can't use water to clean the engine in my 94. So anyone have some pointers on cleaning and detailing the engine area? Also some ideas on cleaning/polishing the alternator and other metal/aluminum engine parts? Thanks in advance!
Old Jun 24, 2008 | 12:20 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
You could wash the engine area if you are extremely carefull not to get any water near the Optispark (behind the water pump). Spray cleaner on the areas that need it, brush with an oled painbursh and then rinse with water flowing from a hose - no nozzle. For the rest of the areas it's some cleaner and rags. I used 00 steel wool to polish up all aluminum bits. There are lots of products available to dress the plastic and rubber parts.
Old Jun 24, 2008 | 01:59 AM
Snakecharmer383's Avatar
Snakecharmer383
Never Dull is your friend!
Old Jun 24, 2008 | 10:53 PM
mcnulty95's Avatar
mcnulty95
Being the lazy bastard that i am, just cleand my engine compartment with some spray on degreaser and hosed it off. As stated above, don't spray the opti. Just use a little common sense.
It took about 10 minutes.
Old Jun 24, 2008 | 11:18 PM
miks139's Avatar
miks139
Thanks for the info guys!
mcnulty, did you paint your rail covers or buy them? I like the look and it would go well with my red exterior and some interior items I am changing to red.
Old Jun 24, 2008 | 11:49 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Don't you have to keep degreaser from the front spring? I was told it would eat thru the gel coat and ruin it? Any truth to that?
RK
Old Jun 25, 2008 | 01:18 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
No hose, or water, rags, brush, Simple Green, alum polish, toothbrush, and alot of work:
To Cleaning Engine Comp.
