Need help with cam and crankshaft positioning for timing chain install
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hello everyone,
I am putting together a L98 engine that has been completely torn down and cleaned up. The question I have is where should the crankshaft be positioned in its rotation, also where should the camshaft be in its rotation? Are there reference marks on the front of them or someway to correctly position them before installing the timing chain and sprockets?
I have a Hanes manaul but I don't have a clear understanding of exactly how everything needs to be set-up. Everything I have found to date is in reference to the distributor
I would appreciate any help provided.
Dave
Dave
![](/forums/images/ranks/5k-6k.gif)
It is really easier than most will make you think. There is a "DOT" on both the cam shaft geat and the crank gear. The dot on the crank should be at 12 o'clock and the dot on the cam shaft gear should be at 6 o'clock. This should be the position for the gears with the chain on.
Line these up and you are ready to go.
Last edited by John A. Marker; 06-29-2008 at 01:43 PM. Reason: correct dot positions
It is really easier than most will make you think. There is a "DOT" on both the cam shaft geat and the crank gear. The dot on the crank should be at 6 o'clock and the dot on the cam shaft gear should be at 12 o'clock. This should be the position for the gears with the chain on.
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
That's backwards, and you stand the chance of installing them a tooth off. The cam dot should be at 6 o'clock, and the crank dot should be at noon. Also, #1 and #6 are at TDC at the same time always, just 180 degrees apart.
RK
RK
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/1k-2k.gif)
t trust your eyes or close enough..It's important that they are in line with each other.....
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
