I used a plastic bondo spreader (yellow plastic ones )they are just right to pry under the emblem so it would not scratch the paint, Then used polishing compound to remove the remaining glue. Also if you decide to replace the front emblem use care not to drop the nuts inside the hole or you will have fun getting them out :)
