85 C-4 Headlight problem - HELP
Old Jul 3, 2008 | 09:31 AM
jerryg01's Avatar
jerryg01
Default 85 C-4 Headlight problem - HELP
I have a problem with the drivers side headlight. When I check the wires to the light, (a green, gray and white wire,) with the lights on, I have no power to the drivers side, but I do to the passenger side. The connection is good. Could this be a relay problem, and which relay is the one to the drivers side light? Also, are all three relays exactly the same? I appreciate any help.
Old Jul 3, 2008 | 11:01 AM
Demonic85's Avatar
Demonic85
Yep its a bad relay, which is found on the driver's side near the battery. I cant remember exactly where it is on my '85 but its not hard to find if you follow the wires.
