lower dash help
Old Jul 3, 2008 | 05:02 PM
vtwindave's Avatar
vtwindave
Cruising
Default lower dash help
working on an 85 with previous owner wiring issues. how do you remove the carpet covered panel under dash on pass side? found 1 screw below fuse panel. took a quick look but didn't see any more. the lower panel with floor light is off. what next ? also what holds the das pad on?
