Dash Pad Skin
Old Jul 6, 2008 | 02:27 PM
Eddywill's Avatar
Eddywill
Default Dash Pad Skin
I see Willcox has a replacement dash Pad skin. Have any of you tackled this project? I know I can buy used units on ebay but I would be interested in replacing the pad if the results are good. Thanks
Old Jul 6, 2008 | 03:34 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Eddy,
On a scale of 1 - 10, I would put this at about a 7 to install. If you have ever done anything like this you may want some advice.
If your pad has cracks in it, they will need to be addressed before you install the skin. (By addressed, I don't mean the old honey mooner line "hello crack"). If you don't repair the cracks and you install the skin as the skin shrinks in the sunlight, cracks that are not repaired will show
To repair a crack you can use several items. One is plastic fusion (plastic weld) or some other type of plastic glue. If the crack is raised, the high part will need to be taken down as to not create a spot in the new skin.
The pad skins have to be glued on and about the best thing you can use is the 3m08088 fast tack trim adhesive! Before installing the skin, it’s a smart idea to use some 600 grit sand paper and scuff up the top of the old pad, as well as the inside of the new skin. This will allow for better adhesion when glued. When you install a skin you will also need a heat gun (or a blow drier). Us this to pull the pad in to position and you will need to do this. If you have an area where the pad skin is not flat, never rub it with a rag directly. Lay a rag on top of the area and rub on top the rag. Using a rag will cause a smooth shinny spot in the skin.
When you have the pad skin on in the proper place, and glued down you can staple it on the bottom of the old frame. To do this you can use an old Swingline stapler or if you have access to a pneumatic stapler this is the ideal tool to use.
Once you have done all this you should be good to go.
It is not a easy job, but will save you tons of money.
Willcox Inc.
Old Jul 6, 2008 | 04:27 PM
Eddywill's Avatar
Eddywill
Thanks for the insight. Does this product have a flat/matte finish like the original pad? I had a dash pad cover that looked good for about 2 years then started to buckle and warp. If its only a seven then I am there - for some reason every project I do turns into an 10..... Way before I was a member here I was a customer on a large auction sight that rhymes with d-day. I have always been pleased with your products and service. Thanks Eddy
Old Jul 9, 2008 | 08:04 PM
0Willcox Corvette
Former Vendor
Eddy, I missed this post I'm sorry. The pad has the correct looking finish to it. I think you purchased a dash cap! JUNK by any standard too! I think the part you are looking at is the actual dash pad skin judging from the picture off our site you posted. If this is the case you will have a fun time installing it. . . As much as I hate to say it, for the time involved in installing (if in a shop), I would buy the pad. If you have the spare time to do it yourself, the I would go with the skin.
I looked you up and appreciate your prior business.
We hate the flea bag and right now we are really getting a strong hatred for Paypal as well.
Seems they are having a problem notifying the sellers that customers have made a purchase. Kind of makes it hard on us. They say they have it fixed, but we had another customer just two days ago that never received his product.
Willcox
To Dash Pad Skin
