need wheel help
Old Jul 9, 2008 | 12:01 AM
shimmy's Avatar
shimmy
Default need wheel help
im getting some c5 wheels the five spokes what do i need to get to make them fit my 84 thanks
Old Jul 9, 2008 | 06:04 AM
Weav's Vet's Avatar
Weav's Vet
Adapters/spacers been discussed here a lot. A search should turn up numerous results.
Basically, you need your current offset and the offset of the new wheels. Subtract to find the difference. Convert that from MM to inches. Probably around 18mm. That should = about 3/4 inch spacers/adapters.
Old Jul 10, 2008 | 12:34 AM
shimmy's Avatar
shimmy
thank you
i tried searchin but it wasnt gettin me what i wanted
Old Jul 10, 2008 | 10:40 AM
WVZR-1's Avatar
WVZR-1
It's not exactly as easy as "that"!
If you were dealing with identical wheel "widths" that will do but you mentioned C5's and you also mentioned an '84. It's much easier in a situation like yours to deal with "backspacing" because you only need two "tools" for correct measurements: (1) a straight edge and (2) a tape measure. Without knowing a good bit more information it's not likely "any of us" could give you a "correct" answer BUT we could all offer up a WAG"! If you know the widths and offsets of what you bought and can tell us what wheels are presently on the car there might be some information that can be passed on to you!
Old Jul 10, 2008 | 02:38 PM
Weav's Vet's Avatar
Weav's Vet
This can be rather confusing not really knowing all of the info. The link below should help the OP with his decision.
http://www.xks.com/corvette/vbp_wheelAdapters.aspx
To need wheel help
