Ive read where your not suppose to use injector cleaner on the multec fuel injectors but will it hurt to add some fuel injector cleaner on my 86' Vette??
your 86 has Bosch injectors. You can run anything you want in them without any problem.
I used in my '96CE with no issues whatsoever! It was cutting out, and loss of power, and now as good as new! (well, not new, but you know what I mean!)
Laura
Would it be safe to use a cleaner on '87 injectors? Thanks.
the 85-88 are bosch.. These injectors can handle alcohol based solvents. 89-94 Multecs (stock) are NOT compliant to any alcohol products especially Ethonol. 95 and up are Multec 2's which are supposed to be self cleaning. But, injector cleaner will not destroy the seals inside the injector like in the 89-94
I was saying to myself "damn, this dude knows alot about injectors", then I read you avitar
Jon,
Thank you very much.Is there a specific injector cleaner that you would advise for my '87 & if so do you supply it?
tankman
Reason: spelling
