Wind deflector problem
Old Jul 19, 2008 | 05:50 PM
CStewTAMU's Avatar
CStewTAMU
Default Wind deflector problem
Are these things supposed to be noisy when the windows are up? Mine are, especially the driver's side. Work great and keeping the wind off your face when the windows are down.
Old Jul 19, 2008 | 07:05 PM
jim_hewett's Avatar
jim_hewett
Mine didn't fit the bottom of mirror bezel. For $25 the fit was cheesy looking. Did you have to trim & fit??
Cheers
Old Jul 19, 2008 | 07:23 PM
Z51JEFF's Avatar
Z51JEFF
Are you using the OEM part or the garbage aftermarket piece?
Old Jul 19, 2008 | 07:26 PM
aboatguy's Avatar
aboatguy
The deflectors factory installed on my 95 VERT are quiet, if yours made more noise somethings not right.
Old Jul 19, 2008 | 08:21 PM
flyinlow90's Avatar
flyinlow90
I bought the OEM part from CC and mine are quiet...
Something must be amiss with yours.
Old Jul 19, 2008 | 10:52 PM
cwyates4's Avatar
cwyates4
What's the noise sound like? If its a windy noise, take a peak up at your top next time you are cruising at highway speeds with the windows up.
My top lifts off the frame a hair at 65+ with the windows up.
Old Jul 19, 2008 | 11:51 PM
CStewTAMU's Avatar
CStewTAMU
I started with the cheap flimsey aftermarket kind and it was noisey. So I got what I think is the OEM part now. It's much sturder, came with the pop rivets, and the top edge is curved instead of pointed. I stuck them on with the tape first, and repositioned the driver's side one twice with no luck. So I just gave up and went ahead and riveted it on.
It's almost like the drivers side and passenger's side isn't exactly symetrical. is there a way to adjust the whole side mirror assembly up or down mayby an 1/8th of an inch or something.
Here's a timeline to help:
1.) Put the cheap aftermarket flimsey wind deflectors on. They kept the wind out of your face when the windows were down, but the driver's side was very noisey the faster you drove.
2.) I repositioned the driver's side delfectors several times thinking I might have it crooked a fraction of an inch and that must be the reason. Didn't work.
3.) Put new A-Pillar/header weatherstripping. Still noisey..no different.
4.) Took off the cheap deflectors and put the OEM (I think they are OEM). Still the driver's side is much noiser.
I think it must be the position of the entire mirror assembly. Mayby I need to pop the door panel off and tweak it a fraction of an inch if it is even adjustable. This really doesn't bother me that much, but if I know there is a way to fix it, I wana try to.
To Wind deflector problem
