Horn relay ?
Old Jul 19, 2008 | 11:34 PM
takovr's Avatar
takovr
Default Horn relay ?
I noticed today on my 1986 corvette that the horn stopped working. When I push on the horn I did here a relay clicking in the dash some were but now I don't here it clicking any more. Does anyone know were the relay for the horn is located ?
Old Jul 20, 2008 | 01:13 AM
jfb's Avatar
jfb
The horn relay is located behind the center of the dash in a plastic box with no top (top is vertical, facing the passengers), called the multi-use center. The horn relay is just left of the center of the multi-use center and low.
Old Jul 20, 2008 | 07:54 AM
Da Mail Man's Avatar
Da Mail Man
...before you tear into the dash, run power directly to your horns and see if they work..if you do and they don't, it would be a horn problem...however, you'll have to decide what is easier to do, get behind the dash or access the horns....
Old Jul 20, 2008 | 08:08 AM
Muffin's Avatar
Muffin
What the Mail Guy said. Another way is to check current to the horn connector when the button is pushed. This will not check your horns directly but will tell you if there is power to the horns.
Old Jul 20, 2008 | 08:15 AM
dlb435's Avatar
dlb435
There is also a fuse for the horn behind the center console, it could be blown.
To Horn relay ?
