I got started...
Old Jul 30, 2008 | 08:33 PM
davidf4925's Avatar
davidf4925
Default I got started...
On changing the opti and water pump on my 95. I also am doing plugs wires, new belt, all new fluids, timing cover seals, fuel filter, and a small paint project. here are some pics of my progress.
here is what it looked like before I started, and also the car up on ramps
[IMG][/IMG]
[IMG][/IMG]
before and after the hoses taken off
[IMG][/IMG]
[IMG][/IMG]
water pump off, look at all the oil
[IMG][/IMG]
crank pully off, that was a pain in the butt
and the paint project
[IMG][/IMG]
[IMG][/IMG]
so far it has been real fun, I'll post pics when I'm done
Old Jul 30, 2008 | 08:36 PM
78pacer's Avatar
78pacer
Yeah, keep me posted 'cause I think I'm not that far behind you.
Btw, what didya use to pop the pulley off?
Mike
Old Jul 30, 2008 | 08:47 PM
davidf4925's Avatar
davidf4925
after reading post on here, I put some pentrating spray on the bolts, after they where off, i had to use some wood and a hammer, and from under the car I carefully tapped it off. I did have to rotate the pully so I'll have to find tdc, but that won't be a problem. I had to do the same thing on my 95 z.
Old Jul 30, 2008 | 09:16 PM
skybolt31's Avatar
skybolt31
Actually you don't have to find TDC, the pulley will only go on the hub one way, the bolt spacing is not equal and there is an arrow on the pulley and hub to line them up. The distributor will also go on only one way.
The funnest part of this job by far is the wires...........
Old Jul 30, 2008 | 09:25 PM
davidf4925's Avatar
davidf4925
I had a lot of trouble getting the stupid #8 plug in, I had no trouble getting it out but putting it in is a pain. tdc is just something I do just to make sure it will fire. I dosent take that long and is kinda cool. Running the driver side wires is a pain.
Old Jul 30, 2008 | 09:28 PM
schrade's Avatar
schrade
ARROW???
Now ya' tell me!!! I got one bolt started in mine, and had NO CLUE why the second or third would not match up.
Nice PCM. '95 huh? Did you know they'll swap with '94's? Wanna' sell yours?
Old Jul 31, 2008 | 09:15 PM
davidf4925's Avatar
davidf4925
I would but I think I need it
To I got started...
