tire size help
Old Jul 31, 2008 | 11:38 AM
geogolf's Avatar
geogolf
Default tire size help
hope someone knows the answer, right now i have 275/40/17 on front of 90 vette and 315/35/17 on rear i bought some 18 inch rims 10 for the frt/12 for the rear what size tire should i run frt/rear so to keep the same rake angle. the rears will be 315/30/18 or 335/30/18 so what size frt thanks for your help geo.
Old Jul 31, 2008 | 12:13 PM
StealthLT4's Avatar
StealthLT4
All you need is to keep the same overall diameter the same. That will preserve your rake as well as the speedo accuracy.
YOUR FRIEND
So, to keep your stock diameters:
FRONT: 285/35-18 (speedo will read 0.8% slow)
REAR: 315/30-18 (speedo will read 0.9% too fast)
335/30-18 will also work on the rear, with the speedo reading 1.0% too slow
Also, I realize the speedo isn't connected to the front wheels. It's just a reference for how much bigger/smaller the diameter of the tire is.
Old Jul 31, 2008 | 07:15 PM
geogolf's Avatar
geogolf
Default tire
stealth thanks for the help do you think i could run 275/35/18 on front and 315/30/18 on rear
Old Jul 31, 2008 | 09:38 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Go here and try any tire size combos you might want;
http://www.corvetteactioncenter.com/.../tirecalc.html
To tire size help
