Where does the console lid button lock ?
Old Jul 31, 2008 | 10:02 PM
Calderone's Avatar
Calderone
Default Where does the console lid button lock ?
i will be gettin soon the console lid spring,my button is ok
when the spring pushes the button out
where does it "lock" ?
on my console there is a little metal attached with a screw
but i suspect this is not original at all.....
any ideas ? and where can i get that "little part"
thanks
Old Jul 31, 2008 | 10:28 PM
blankmantn's Avatar
blankmantn
Thats where it locks....I am looking for one of those little "L" shaped metal clips myself. Mine was missing when I bought my car.....Let me know if you find any!!
Old Jul 31, 2008 | 11:07 PM
Calderone's Avatar
Calderone
i have it but i think its a "bootleg" custom made one
because somehow ...it does not lock it !
i have the nice cushion it adds weight to the lid and it does not open
but i would lke to have it "locked" and press the button to open it.-
i will try to "adjust it"
Old Jul 31, 2008 | 11:34 PM
Eddie & the Cruisers's Avatar
That's how they are built. Lock it with the key.
Kind of cheesy I think for such an excellent sports car.
You can adjust the little clip so it catches the button latch. You may have to bend it some to make it engage the latch. Come to think of it, I'd like mine to latch with the button too.
Mine doesn't have a spring that pushes up on the lid. Where does the spring go? I see a small round hole by the key lock pawl up on top. Is that it?
Old Aug 1, 2008 | 12:20 AM
Calderone's Avatar
Calderone
the spring goes on the lid it pushes the button out.-
i dont have the console key
its different from the door
Old Aug 1, 2008 | 01:47 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First try adjusting position with the scew loose; if that doesn't work try removing the metal latch and bending it a tad.
There is a spring inside the latch mechanism; if you press in on the button it should spring back into the "latched" position.
The OEM spring is a small leaf spring; after mine broke I "rigged" a very small coil spring from a tiny ball pen.
Old Aug 1, 2008 | 09:22 AM
T J's Avatar
T J
Cruising
My lock is located on drivers side of console...locks with door key...had to make a new "L" latch though..mine kept bending..was easy fix though.
Old Aug 1, 2008 | 09:27 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can order the entire console lid spring and latch assembly from Mid America Motorworks (MAM). That's where I got mine.
Old Aug 1, 2008 | 02:50 PM
65Z01's Avatar
65Z01
Yep, here ya go link.
Old Aug 1, 2008 | 03:37 PM
aquablue96's Avatar
aquablue96
Ecklers sells them also!
Old Aug 1, 2008 | 03:44 PM
Calderone's Avatar
Calderone
Yes we know,we are talkin' about the actual "lock" latch
its an L shaped part,nowhere to be found .-
thanks anyway !
Old Aug 1, 2008 | 11:46 PM
Thanks, mine is intact and works fine. I thought you meant a spring to push the lid open and up a little.
Yours must be an earlier model where they used to have a third key just for the glove box/trunk cars.
Old Aug 1, 2008 | 11:50 PM
Calderone's Avatar
Calderone
thanks you solved a big mistery for me
because i have made a post about it ...
and now i know that the inner stuff has different keys !
somehow i knew it, thanks !
To Where does the console lid button lock ?
