LT1 Engine Specs
Old Dec 30, 2001 | 10:43 PM
95AquaC4's Avatar
95AquaC4
Default LT1 Engine Specs
Looking for a complete list of specs for the LT1 engine. Cam profile, flow #'s etc. Thanks!
Old Jan 1, 2002 | 03:50 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: LT1 Engine Specs (95AquaC4)
Sounds like someone got a copy of "Desktop Dyno" for Christmas?
If you specify, someone around here may have an LT1 model built already.
Old Jan 1, 2002 | 04:09 AM
SPEEDEMON's Avatar
SPEEDEMON
Here you go, I hope this can help you:
Block: Cast iron, short skirt
Bore x Stroke (in.): 4.00 x 3.48
Displacement: 350 cu in, 5733 cc
Crankshaft: Cast iron
Torsional Damper: Single mass
Main Bearings: Center Caps 4-bolt End caps 2-bolt
Connecting Rods: Powdered metal
Pistons: Eutectic aluminum/silicon alloy (Mahle 142)
Cylinder Heads: Aluminum, 2 valves/cylinder
Valve Diameter: Intake/Exhaust (in.) 1.94/1.50
Rocker Arms: Conventional
Valve Springs: Round Section
Cam Drive: Link chain, powdered-metal sprockets
Valve-Open Duration, Intake/Exhaust (in.): 279/276
Valve Lift, Intake/Exhaust (degrees): 0.447/0.459
Valve Overlap (degrees): 41
Compression Ratio: 10.4:1
Fuel Injection: Electronic sequential port
Fuel Recommendation: Premium Unleaded
Ignition: Electronic, platinum tip spark plugs
Horsepower (hp @ rpm): 300 @ 5,000
Torque (lb-ft @ rpm): 340 @ 4,000
Redline (rpm): 5,700
Old Jan 1, 2002 | 12:57 PM
95AquaC4's Avatar
95AquaC4
Matt, Exactly right!! want to build a stock LT1 in Desktop Dyno!! Speedemon, Thanks, that should help alot!!
To LT1 Engine Specs
