Top interchangable?
Old Aug 7, 2008 | 03:58 PM
JAKE's Avatar
JAKE
Default Top interchangable?
Will a top from a 86 fit a 96?
My son's been offered (for free) a clear top for his 96, but it's off a 1986. No need in taking it if it won't fit.
Thanks for any help.
Jake
Old Aug 7, 2008 | 04:01 PM
NEVRL8T's Avatar
NEVRL8T
I think they changed the fastening system for the tops in that time period. I could be wrong. They all use the same bolts but I think the bolts might have been in slightly different place.
Old Aug 7, 2008 | 04:13 PM
captmike13's Avatar
captmike13
Cruise-In IX Veteran
Won't fit. The breakdown is 84-E86, L86-88 and 89-96.
Hope this helps.
Mike.
Old Aug 7, 2008 | 05:13 PM
aquablue96's Avatar
aquablue96
The breakdown above is correct however it is an easy change. Matter of fact I saw the older brackets on ebay the other day for cheap.
http://cgi.ebay.com/ebaymotors/83-84...mZ230278986498
The only difference is where the screws mount. This converts it to the older (86) style.
Old Aug 7, 2008 | 06:17 PM
Chatman's Avatar
Chatman
You will also need the vinyl that runs across the top of the windshield -- that aside, free is a good price.
Old Aug 9, 2008 | 02:23 PM
JAKE's Avatar
JAKE
Thanks for all the feed-back. I'll pass it along to my son.
Jake
Old Aug 9, 2008 | 03:07 PM
cwyates4's Avatar
cwyates4
If that top is from an early '86, give it to me!
Old Aug 9, 2008 | 04:41 PM
Happydad's Avatar
Happydad
I just Happen to have 3rd Gen Brackets........40.00 + 9 bucks shipping
Old Aug 9, 2008 | 04:47 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I've got an early 86 on my 95 just had to replace the brakets.
Old Aug 10, 2008 | 06:46 PM
Impala Balko's Avatar
Impala Balko
I have an 84-86e fiberglass top on my 94 vette and I didnt convert the brackets on the car.... I just converted the brackets on the roof. Its very do-able and quite easy.
Old Aug 10, 2008 | 08:30 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Could you PM with the procedure? Thanks
Old Aug 11, 2008 | 08:43 AM
Impala Balko
I converted an 84-86E top to fit a 89-96 style roof.
* What I did is I took the brackets that bolt to the
top and I screwed them to the mounts on the top of the windshield.
* I then took some white washable paint and painted
the underside of the brackets so when I literally rest
the roof on the top of the car it leaves and imprint
on where I should drill the holes.
* I drilled them and tapped the holes then mounted
the mounts and it the top fit perfectly even better
than the one that came with the car.
* Then I put some Red Lock tite and made the mounts permanent.
I posted a thread last year about it which I think might cover it better with some pics
To Top interchangable?
