1988 console trim
Old Aug 8, 2008 | 12:44 AM
terry riffle's Avatar
terry riffle
3rd Gear
Default 1988 console trim
does anyone know the procedure to disconnect the cigarette lighter housing in order to facilitate removal of the console trim plate on a 1988 with A/T? I'm trying to re-adjust the neutral start/back-up light switch.
Old Aug 8, 2008 | 07:08 AM
pbergmann's Avatar
pbergmann
You need to remove the instrument bezel, move right to the center where the radio and AC bezel is, remove that. Then you will be able to remove the console trim plate. just be careful as these plastic parts are fragile.
Old Aug 8, 2008 | 01:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have to loosen the IP bezel so I can move it enough to the left to remove the radio bezel for access to lift the console cover plate...
Old Aug 8, 2008 | 04:57 PM
Jims1988C4's Avatar
Jims1988C4
I can't get the boot off mine.it looks like its just stuck do to age and Im afraid to force it
Old Aug 8, 2008 | 05:06 PM
JonnyAngle's Avatar
JonnyAngle
a wiseman once said, "If it doesn't fit, force it. If it breaks, well it needed to be replaced anyway."
To 1988 console trim
