Valve seals done
Old Aug 10, 2008 | 02:24 PM
Jim D's Avatar
Jim D
Default Valve seals done
No more smoke on startup. on to the next project, Jim.
Old Aug 10, 2008 | 02:26 PM
Eddywill's Avatar
Eddywill
Jim did you remove the heads?
Old Aug 10, 2008 | 02:28 PM
PAINTER MAN's Avatar
PAINTER MAN
No need to remove the heads to do valve seals. I did mine this winter
Old Aug 11, 2008 | 03:01 PM
clok1966's Avatar
clok1966
How long does it normally take (the air presure, none remove heads method?) I have done seals when i did valve jobs before (20 years ago). With the correct spring compressor, how long can a guy plan on for this project? Do you guys all make sure the piston is TDS on each cylinder when doing this?
the smoke on starte up while nothing really is embaresing.
Clok
Old Aug 11, 2008 | 05:50 PM
Jim D's Avatar
Jim D
Well.I'm old and slow , took me about 8 hrs, over 2 days. I know some of the young, and more experienced guys do it in about 4 hrs. Jim.
Old Aug 11, 2008 | 06:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Well I did the seals AFTER I had done the RRs so 2nd time in wasn't quite as long...
I'd say it could be done in a day but a weekend ain't a bad idea.
I used the "rope trick" to assure no chance of a dropped valve so the pistons were at TCD.
Old Aug 11, 2008 | 06:12 PM
PAINTER MAN
I was in no hurry last winter when I changed them. I have no idea how long it took.
Old Aug 12, 2008 | 01:14 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
Jim, You have an 87. How did you deal with the EGR pipe? DId you remove the exhaust manifold as the FSM suggests, or did you wrestle with the clamp? I've got everything to do the job, and I'm hesitating because of that one thing.
Old Aug 12, 2008 | 02:13 PM
clok1966's Avatar
clok1966
Rope trick? could you explain?
thanks!
Clok
Old Aug 13, 2008 | 01:05 AM
pletzvet's Avatar
pletzvet
Same here - I'd estimate I took 8 hours this spring. Booked a couple of days vacation that I had to burn up or lose and spent them - just me and the vette in my garage. Took my time, and played things doubly cautious, by rotating the crank so each piston was just a bit before TDC and used air. Once the valve springs were removed, I just shut the compressor off and let the valves sit on top of the pistons while I puttered away. Clamped a set of vice grips with rubber hoses on the jaws on the crank pulley and wedged against the front cross bar otherwise the crank would rotate when I put the air in the cylinder. I seem to remember using about 70 lbs when tapping the retainer to loosen it from the keepers and about 35 lbs when re-installing the seals, springs, keepers etc. A very rewarding job when it's done!
Old Aug 13, 2008 | 07:19 AM
rich653's Avatar
rich653
When I did mine getting the clamp off the egr pipe was a PIA but I was able to knock it off with a long punch. I never did put it back on, I straightened it out and put in in my tool box in case i had a problem but I haven't so far. I just set the pipe in place and tightend the manifold bolts so far so good.
Old Aug 13, 2008 | 07:32 AM
94z07fx3's Avatar
94z07fx3
thanks!
Clok
I haven't done this but the rope trick is stuffing a quality length of rope into the sparkplug hole until no more rope will fit easily and then squishing an extra inch or so in. If the crank turns and the valve falls it will be on soft rope fiber and not on a hard piston top.
Old Aug 13, 2008 | 11:17 AM
pletzvet's Avatar
pletzvet
Just a slightly different theory...I've only used the rope trick on small engines to keep the crank from rotating when removing a clutch or flywheel (e.g. lawn mowers, sleds). My understanding of the rope trick is to insert some rope through the spark plug hole, when the piston is approaching TDC, then when there is a sufficient amount of rope in the cylinder, turn the crank a little more until it stops because the rope is now compressed against the head and the valves. This will keep the valves from dropping when the keepers are removed and then the seals can be changed with the full length of the stem accessible to you. A bit tedious because you have to turn the crank in reverse to release the pressure on the rope in order to remove it from the cylinder - but it will work!
To Valve seals done
