Downloading pictures HELP!
I transfer my pictures to Car Domain. Then view the picture full sized. If you then press the mouse button on the right side of the mouse..several options will appear on the screen. The important one is properties. If you click this option, it will display the properties on the screen. It will display the address (URL), if you highlight this and press the control key and the "C" key at the same time you copy this into memory. Then go to your thread you want the picture in and type "[img] then hit the control key and the "V" key and it will paste the URL address. Now type [/img]" (leave out the " marks) after the address and you should be good. Like this
You could hide stuff in there, like some crazy modicators!
Picture is deceiving.....it is the stock L98 coming out of my 85. All original bottom end....no over sized pistons. 223,000 miles on it when the head gasket blew. Made the decision to drop in a ZZ4 short block built for a roller cam.
What is REALLY DECEIVING is the old man pulling the engine...me
